Old 01-05-2004, 01:07 PM   #1
TheMadScientist
Member#: 23717
2005 Big red
Default Has anyone tried using GM part# 1997152 boost control solenoid
Do NOT do this mod if you are using a reflash or Cobb AP
It will result in over boosting and boost spikes. Unless you have DeltaDash.
This part is the boost control soleniod for a GMC cyclone. Has anyone tried it? I might buy one to try as they are only $20. If it can flow more than our stock one then I might be able to remove the ABC for the Utec and still hit the higher boost #'s.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-05-2004, 03:24 PM   #2
shields102
Member#: 9598
02 wrx
white
You can up the size of the hoses leading to and from the bcs and achive the same thing. I have an ecutek tune but I don't see why it would be any different.
shields102 is offline   Reply With Quote
Old 01-05-2004, 03:33 PM   #3
EMS2
Member#: 45061
Or simply reduce the restrictor hole diameter........
Mark.
EMS2 is offline   Reply With Quote
Old 01-11-2004, 02:21 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
Well I bought one. When I first looked at it I thought it was a two port solenoid. After a closer look it is a three port solenoid with a small mod. I have not had a chance to play with it yet way to cold out, but this might be a cheap three port solenoid. They list for ~$20. The subaru one from the legacy is ~$190. I am not going to use this for direct boost control but I am going to use it to switch in a MBC under WOT only. Then there is no PTFB to worry about. Here is a pic after the mod. The mod is there is a piece of foam and a clip on one of the ports. A pair of side cutters took the clip right off.
TMS
Old 01-11-2004, 02:21 PM   #5
TheMadScientist
Member#: 23717
2005 Big red
Pic
Old 01-12-2004, 03:03 AM   #6
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
I'minterested in the results, especially since my subaru boost solenoid likes to stop working with me
Any chance of you trying to use this as a substitute for the factory boost controller?
thebusiness999 is offline   Reply With Quote
Old 01-12-2004, 09:26 AM   #7
TheMadScientist
Member#: 23717
2005 Big red
That was going to be what I was going to use this for. But since it is a three port solenoid that was designed to be used under the hood of a car I am going to use it for my BOV and my dual boost control set up. If you want to try it the solenoid itonly cost ~$20. Go for it.
I just soldered and epoxied leads to the conector and am waiting for the epoxy to setup. I will be playing with it tonight.
TMS
Old 01-12-2004, 11:10 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i'm wondering why you're not thinking of using the tried-and-true 3 port grainger solenoid? it's about the same cost.
ken
Old 01-12-2004, 11:12 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
tms, if you're interesting in an electronic throttle switch i have a schemo for one on my website. it works perfectly.
ken
ps. i had a gander at your PNP work on that exhaust housing saturday... i am curious as to how the test results come out.
Old 01-12-2004, 11:20 AM   #10
TheMadScientist
Member#: 23717
2005 Big red
ken
Thanks for the offer. I am going to use the Utec to control the solenoid.
Since the housing was just installed this saturday I am not expecting any results for at least a week. The results will be posted when testing is done.
ken
Because I could not find one that had the required PSI rating. I don't know if this one does either. At least this one is for use under the hood of a car.
TMS
Old 06-10-2004, 06:45 AM   #11
TheMadScientist
Member#: 23717
2005 Big red
Well I installed this on my Sti last night in place of the stock BCS.
The resistance of the GM solenoid is 24ohms and the resistance of the stock solenoid is 32ohms. I wired in a 10ohm 1watt resistor in one wire going to the GM solenoid as a current limiting precaution.
I think this would be a great mod for people running user tuneable EM. With the GM solenoid installed the way I have it you are directly controling the WG duty cycle, you are no longer using a bleed system for boost control. So I would think that you could remove the ABC and still run the boost you want. I don't have any restrictors in the boost control lines. I still get full boost infact I think the boost response between gears is much better.
If anyone is interested in more info let me know.
TMS
Old 06-10-2004, 11:13 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
tms, are you using a utec or other em to control bcs duty cycles?
ken
Old 06-10-2004, 11:56 AM   #13
TheMadScientist
Member#: 23717
2005 Big red
No the stock ECU seems very happy right now. No CEL solid boost no over shoot. At first the boost was a bit lowwer than normal. But two runs at WOT and the ECU seem to have adapted very well.
I think with the Utec you should see much better spool because you shut off the signal going to the waste gate. Also there should be no need for the ABC.
TMS
Old 06-10-2004, 01:46 PM   #15
fastlane
Member#: 17470
2002 WRX Wagon 5 Spd
^^Nomo - 04 GT Stang now
Same here...please send any information my way as well.
fastlane is offline   Reply With Quote
Old 06-10-2004, 02:03 PM   #16
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
I'm gonna have to watch this thread...
Kwyjibo is offline   Reply With Quote
Old 06-10-2004, 02:17 PM   #17
Kristopher
Member#: 16790
'95 Rover Classic
Kristopher is offline   Reply With Quote
Old 06-10-2004, 03:49 PM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ahh, i think i see what you've done...
instead of the stock system which uses the solenoid to remove the pressure signal from the direct line between compressor and wastegate actuator, you now have a system which uses the solenoid in series with this line. so where the old stock system would keep the solenoid close to prevent the boost from rising, the new system keeps the solenoid open to achieve the same result.
and the most amazing thing is that the ecu learned around the completely new boost response!
good stuff...
edit: i'll measure both my grainger solenoid and my FBC solenoid tonight for electrical parameters.. Rdc and L (inductance). if the replacement solenoid has appreciably more L we might have to add an extra "snubber" diode to prevent a voltage spike from wiping out the driver circuitry.
Old 06-11-2004, 09:32 AM   #19
TheMadScientist
Member#: 23717
2005 Big red
good stuff...
You are corect in the way the solenoid is hooked up. I have had it on the car for two days now and there has been no problem.
The GM solenoid is a three port device. On one end there is a common port that has a metal fitting, run that one to the compressor cover nipple. On the other end of the solenoid there are two hose barbs, one is covered by some foam and a metal clip remove the foam and clip. With no power to the solenoid one of the two ports is conected to the common port that open one goes to the wastegate nipple. The port that is closed with no power goes back to the intake. For wiring I soldered wires to the pins in the conector of the solenoid and filled the conector with epoxy. The 10ohm 1 watt resistor goes in series with the soleoid.
If I draw a diagram can someone host it and post here?
TMS
Old 06-11-2004, 11:08 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
tms, send it my way. email attachment is fine.
Old 06-11-2004, 01:55 PM   #21
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
how many psi can the solonoid handle??
thanks.
Old 06-12-2004, 11:54 AM   #22
TheMadScientist
Member#: 23717
2005 Big red
Email addy?
TMS
Old 06-12-2004, 01:05 PM   #23
vile
Member#: 32371
'02 t-rex wagon
platinum
i need visual
can we get some diagrams? pics?
thanks
vile is offline   Reply With Quote
Old 06-13-2004, 02:33 AM   #24
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
If you guys don't want to solder, you can find the connector that plugs directly into the solenoid if you search for part #12052641 on this website... http://www.powerandsignal.com/IDC/DisplayResults.aspx
I'm using this solenoid for something else entirely, but it does appear to work very well in this capacity.
DjRez4 is offline   Reply With Quote
Old 06-13-2004, 10:37 AM   #25
TheMadScientist
Member#: 23717
2005 Big red
ride I just sent the quick diagram to you.
I know there will be more questions after you post it I will answer them as soon as I can.
DjRez4 you have used that connector all ready? Nice find.
TMS
Has anyone evr used a PK3 Transponder bypass system for GM vehicles? BGPunk2001 Off-Topic 17 05-01-2008 05:37 PM
Has anyone tried this? Die Civic Car Care & Detailing 16 12-31-2000 11:40 AM
has anyone tried the ICON chip from ISR? scootr Normally Aspirated Powertrain 1 11-07-2000 10:50 AM
Has anyone tried this....... AndyL General Forum Archive 0 10-10-2000 02:08 PM
Has anyone tried the primitive pads? Tim Prudence Technical Forum Archive 5 06-23-2000 08:20 AM
