Old 01-05-2004, 02:47 PM   #1
xfactor834
Member#: 12506
Default How do you delete a file that can't be deleted???
"This file cannot be deleted since it is being used by another program".
But it's not!
How do I delete it? Isn't there a free program that overwrites something like this and deletes it anyway?
xfactor834 is offline   Reply With Quote
Old 01-05-2004, 02:48 PM   #2
CoiloverKid
Member#: 29650
Lady Gaga fan club
GDB & RX7
CoiloverKid is offline   Reply With Quote
Old 01-05-2004, 02:51 PM   #3
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
what is the file name?
what operating system?
mattjk is offline   Reply With Quote
Old 01-05-2004, 02:51 PM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
assuming windows:
something probably does have it in use. go to sysinternals.com and get process explorer. it's freeware and will tell you what files are open by running processes. kill the process using it and delete the file.
if it's really not being used, then chkdsk should repair the file and/or security descriptor causing the problem.
ColinL is offline   Reply With Quote
Old 01-05-2004, 02:52 PM   #5
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
maybe reboot into safe mode?
MikeWRX-NJ is offline   Reply With Quote
Old 01-05-2004, 02:53 PM   #6
99WNX
Member#: 14174
03 Cobra 836 rwhp
99 Lightning 453 rwhp
grap on your teh computer skillz!!1!!!1
99WNX is offline   Reply With Quote
Old 01-05-2004, 02:53 PM   #7
Stroke
Member#: 12208
1998 Pick'm up truck
format c:
Stroke is offline   Reply With Quote
Old 01-05-2004, 02:54 PM   #8
Saunders
Member#: 34480
2003 WRX Wagon
If you are in w2k or winXp, reboot into console mode (command prompt only) and delete it that way. No processes to mess it up
Saunders
Saunders is offline   Reply With Quote
Old 01-05-2004, 02:54 PM   #9
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
low level format
imprezton is offline   Reply With Quote
Old 01-05-2004, 02:55 PM   #10
Grap
Member#: 6590
IBtrytheBCCfield
Grap is offline   Reply With Quote
Old 01-05-2004, 02:58 PM   #11
CosmoTheCat
Member#: 3409
Saunders
or 95/98... dos/command prompt rules. now, make macos 9 do a command prompt and I'll be happy.
CosmoTheCat is offline   Reply With Quote
Old 01-05-2004, 03:00 PM   #12
xfactor834
Member#: 12506
you bastards.
it's winXP, it's a movie trailer that sits its fat ass on my desktop in *.avi format.
Old 01-05-2004, 03:01 PM   #13
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Originally posted by xfactor834
you bastards.
just restart your computer and try deleting it again.
Old 01-05-2004, 03:02 PM   #14
Stroke
Member#: 12208
you bastards.
Oh.
Rub a big magnet on the side of the hard drive. That'll get it for sure.
Old 01-05-2004, 03:03 PM   #15
Foovanadil
Member#: 23515
2011 Legacy GT
Steel Silver Metallic
yes.
your media player probally still has a handle on it. Reboot and it will release the file handle and then you can delete it
Foovanadil is offline   Reply With Quote
Old 01-05-2004, 03:03 PM   #16
99WNX
Member#: 14174
03 Cobra 836 rwhp
Old 01-05-2004, 03:04 PM   #17
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
ctrl-alt-del opens task manager, kill explorer
in task manager, goto run, enter cmd and hit enter (opens command prompt)
using old dos commands, change to directory containing file, type del <filename> and then exit.
Now in task manager, goto run, enter explorer.exe and hit enter
explorer should come back and the file should be deleted. if you get a similiar file in use error in dos as well, then you need to find the offending process and kill it. I find that XP sometimes leaves files undeletable for no reason quite often.
Akirasoft is offline   Reply With Quote
Old 01-05-2004, 03:12 PM   #18
xfactor834
Member#: 12506
i tried restarting. didn't work.
i can do the old-school trick with DOS and delete it manually, but won't the icon still appear on my desktop?
Old 01-05-2004, 03:33 PM   #19
rbehny
Member#: 1908
the only way it would stay on your desktop is if it was a link to the actual file. So if it says *.lnk then yeah just delete it off the desktop after you delete the actual file through the dos commands.
rbehny is offline   Reply With Quote
Old 01-05-2004, 03:47 PM   #20
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I would boot with a Win98 boot disk. Delete the file and it shall be gone.
Jard is online now   Reply With Quote
Old 01-05-2004, 04:14 PM   #21
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I had this exact same problem! OT finally got it to work for me.
Do a search for my name and "Star Wars" in OT or something like that and you will find out how to do it. It was about 3 months ago probably.. I forgot
Eric SS is offline   Reply With Quote
Old 01-05-2004, 04:15 PM   #22
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I got un-lazy and searched for you
http://web2.nasioc.com/forums/showth...ight=Star+Wars
The last thing they said to do worked where I had to open a command prompt and delete it from the directory.
Old 01-05-2004, 04:22 PM   #23
xfactor834
Member#: 12506
thanks eric...i'll try later when i get home.
Old 01-05-2004, 04:24 PM   #24
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
NP. Good luck.
Old 01-05-2004, 04:26 PM   #25
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
in order to delete it from the command prompt without recieving the same message, you have to kill explorer first
Everything you need at prices that can't be beat! Don't pass this up! maperformance Engine/Power/Exhaust 63 07-07-2007 01:13 PM
Everything you need at prices that can't be beat! Don't pass this up! maperformance Suspension/Brakes/Handling 79 07-07-2007 01:12 PM
Everything you need at prices that can't be beat! Don't pass this up! maperformance Drivetrain 34 06-22-2007 12:59 PM
how do you play CCD file and SUB file? lionken07 Off-Topic 3 07-23-2004 11:39 AM
a thread topic that can't be deleted, puppies -LD Off-Topic 20 02-18-2003 10:44 PM
