#1 |
Member#: 552
Vehicle:SOHC RS-Turbo EJ257 Tec-2 Aquamist 2D |
I have a set of 4 RC 550 injectors for sale. Selling because I need bigger ones. These are $95 a piece from RC Engineering website, Click Here for new price. I am asking $290 shipped.
#3 |
Member Sales Rating: (8)
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Out of curiosity, how much were those fuel rails? If you dont mind. I've been looking for a fuel rail kit for my 99 impreza.
#8 |
Member#: 552
Jay, that's RTV silicone you're seeing there, used for added sealing. There is a rubber o-ring seal inside the manifold, close to the tip of the injector.
#10 |
Member#: 552
It worked pretty good. The secret is to rotate the injector a few turns in the injector bung after you have applied the silicon. |
#11 |
Member#: 7534
Vehicle:99 impreza rs-t rally blue pearl |
Boost-up- how much power are you running right now to be needing bigger injectors? I was told you will never get it to idle right if you go any bigger CC's! I am running 300WHP @13pounds of boost with no fuel problems and the same set-up.
I am wondering if i should install secondary injectors or go bigger? (I Want to hit the 400WHP mark) |
#12 |
Member#: 552
Running zero HP now....engine's out of the car.
I was running about 250 whp at ~80% IDC. I am currently building up the engine a little to hopefully support more HP and don't want to run out of injectors later. Idling shouldn't be a problem with proper tuning, granted you'll not have OEM quality idle but it'll be acceptable for a loud and rough car. For what it's worth, my friend's WRX is idling ok with 800 cc/min injectors. |
#13 |
Member#: 7534
If 1800 rpm is acceptable then its all you! You know you can run a second set of injectors controled by the tec? It will take a tuning guro like Shiv to tune that thing
#14 |
Member#: 552
No, no 1800 rpm idle here....should be around 900 +/- 100 rpm. My idle with the 550's was at a nice 700 rpm. Where did you get the 1800 rpm idle from?
That's pretty crazy....I still want to keep my car as a daily summer car. |
#16 | |
Member#: 552
Why is there no interest in these injectors??
#19 |
Member Sales Rating: (22)
Member#: 733
Vehicle:'13 Focus ST '85 GTi rally/road race |
Toon - You haven't called me to watch the transformation of the beast into the killer beast???
![]() I'll have the turbo wagon in a week or so (it's actually in my driveway but not titled or plated in my name yet...) ![]() I wanna see the progress on the car so give me a jiggle or PM me. ![]() -mykr. |
#20 |
Member#: 552
That's because I haven't done much at all, Mike. I pulled the motor over x-mas and finally today I disassembled the heads from the block.....that's it. More will get done once all my parts get in.......damn custom stuff takes forever....
I think your STi wagon needs some 550 injectors ![]() |
#22 |
Member#: 552
I use them in my 2000 2.5RS intake manifold but they are standard size and will fit most any engine that has top feed fuel rails. The o-rings on the top and bottom are about 15mm O.D.
My buddy has a set of these in 1000 cc/min size on his WRX....so that means they'll fit WRX manifolds too. |
#24 | |
Member#: 11786
Vehicle:02 TS Black on White |
Damn ![]() |
#25 | |
Member#: 733
![]() Let me know if you need a helping hand. -mykr. |
| Thread Tools | |
| Display Modes | |
| FT: 550 CC topfeed injectors Denso | Turbo II-FB | Engine/Power/Exhaust | 2 | 05-24-2007 07:21 PM |
| FS: 2004 Sti 550 cc/min side injectors - excellent condition | mazdman | Engine/Power/Exhaust | 0 | 01-07-2007 11:19 AM |
| RC Engineering 650 CC Injectors high impedence for 99rs | White 2.5rs | Private 'For Sale' Classifieds | 18 | 12-07-2005 07:02 PM |
| FS: Greddy Type S (new) / 550 CC STi injectors / exhaust stuff | LowNSlowNeon | Private 'For Sale' Classifieds | 24 | 03-08-2005 05:14 PM |
| 550 CC STi Injectors | LowNSlowNeon | Private 'For Sale' Classifieds | 8 | 03-04-2005 05:11 AM |
