Old 01-05-2004, 03:24 PM   #1
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
Default Which gauge to use to monitor my O2 bottle
What type of gauge should I use if I want to monitor the full/empty level of my O2 bottle?
jikhead is offline   Reply With Quote
Old 01-05-2004, 03:40 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
since when do cars have bottled O2?
nhluhr is offline   Reply With Quote
Old 01-05-2004, 04:09 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
That would be a good one....o2 injection!!!
Old 01-05-2004, 04:41 PM   #4
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
2004 federal regulations require all US vehicles provide oxygen for cars that see altitudes of 15,000 feet or more.
Persons found operating a vehcile at this altitude withouth o2 provisions will be subject to a 50,000 fine and up to 5 years federal prison.
tolnep is offline   Reply With Quote
Old 01-05-2004, 06:38 PM   #5
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
Sorry I meant CO2 bottle
Old 01-05-2004, 11:51 PM   #6
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Probably just a N2O gague or some other gague that reads pressure. What kind of pressure range does the bottle run at.
roybfr is offline   Reply With Quote
Old 01-06-2004, 12:00 AM   #7
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
Use a N20 gauge, I think autometer makes a few.
MB38 is offline   Reply With Quote
Old 01-06-2004, 03:45 PM   #8
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
N2O gauges measure pressure, which won't give you a strong indication of how full the bottle is, only what the pressure of the gas sitting on top of the liquid N2O is... this will be heavily affected by temperature and recent usage.
If you want to accurately measure the level of liquid N2O, you need a dip-style level gauge (like they use in underground fuel tanks) but I don't think there are any available that will be cost-effective for a 10lb bottle.
Your best bet is to mentally keep track of how many times you use it vs how many runs you can get out of a bottle.
Old 01-06-2004, 03:57 PM   #9
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
C02 for an onboard fire extinguisher?
Old 01-06-2004, 05:02 PM   #10
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Ntercooler?
MAD REX is offline   Reply With Quote
Old 01-06-2004, 05:21 PM   #11
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
I use the DEI intercooler sprayer
Old 01-06-2004, 05:22 PM   #12
nester
Member#: 49839
2002 WRX Wagon
you could maybe use a Keg co2 tank style gauge
http://www.beveragefactory.com/draft.../exp-742.shtml
I'll admit, I have no idea if that would do anything for you... but I do know it will read the volume of a co2 tank.. :dunno:
nester is offline   Reply With Quote
Old 01-06-2004, 05:23 PM   #13
WRXMikeH
Member#: 30577
2003 WRX
Liquid N2O and CO2 have similar pressures at room temperature, so a N2O gauge will work just fine. Like nhluhr said, it's really only reading the pressure of the gas above the liquid (which is at the same pressure). On the gauge, the pressure shown will remain fairly constant while there is liquid left in the bottle. It will fluctuate with temperature, however. Here's a chart:
Liquid CO2 operating pressure vs. temperature
80F=969 psi.
70F=853psi.
60F=747psi.
50F=652psi.
40F=567psi.
30F=491psi.
20F=422psi.
If you can keep the bottle at a fairly constant temp (you should) then the pressure gauge will really only tell you when the bottle is very near empty. It's better than nothing, any other measurement method just isn't cost effective.
Edit: That chart is just an estimation
WRXMikeH is offline   Reply With Quote
How to use PC monitor for Wii via DVI connection? shemoves Off-Topic 17 11-06-2009 12:44 PM
IMB Thinkpad, switch/key to use extrenal monitor?? Bonzo Off-Topic 2 12-17-2004 10:46 AM
What wire to use to hook up my Air fuel gauge? BrysImpreza Forester Forum 3 02-22-2004 01:49 PM
Which gauge to use for monitoring CO2 bottle jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-06-2004 11:54 AM
Which tool to use to cut a urethane greddy lip? bigbird Interior & Exterior Modification 4 04-29-2003 07:51 AM
