Old 01-06-2004, 12:55 AM   #1
phatroksek
Member#: 7397
2014 BRZ
Default utec on jdm motor
hey everyone,
i'm going to soon swap in an '03 JDM WRX engine, non-STi. i'm wondering if it possible to tune it using a UTEC being that the JDM EJ205's are different then the USDM EJ205's from the ECU to the cams to the variable intake valve timing heads to the running on higher octane gas?
if a UTEC is no possible to use, what other direction should i be looking in to tune correctly?
thanks!
phatroksek is offline   Reply With Quote
Old 01-06-2004, 02:39 AM   #2
Stang2WRX
Member#: 35899
'03 Cobra
Sonic Blue
I think you should be able to use usdm ecu if you want to use UTEC.
Stang2WRX is offline   Reply With Quote
Old 01-06-2004, 02:40 AM   #3
cronic
Member#: 9749
But then you get no AVCS and that is no fun!
cronic is offline   Reply With Quote
Old 01-06-2004, 02:42 AM   #4
phatroksek
Member#: 7397
2014 BRZ
if i use a usdm ecu then yes, there goes all the goodness of the jdm motor
Old 01-06-2004, 03:05 AM   #5
cronic
Member#: 9749
Hit up Kingpin or AZscoobie on these forums. Mike and Clark have tuned a bunch of JDM swaps and can set you up with an ECUTEK tune for you mods.. We are trying to get them out here in early to mid spring for another dyno day(search for tri state dyno day in PPB forums) in which you can have your existing map tuned on the dyno, since you are right here in jersey.. THey have tuned A LOT of JDM swaps and know there way around the JDM ecu like no other so definetly get into contact with them..
Dave-
Old 01-06-2004, 03:12 AM   #6
phatroksek
Member#: 7397
2014 BRZ
oh wow, thank you so much, that's the type of answers i'm looking for when i post threads
Old 01-06-2004, 10:01 AM   #7
nmyeti
Member#: 4980
We have a UTEC that works for JDM ECUs. You simply need to mention that when you order your UTEC. Your best bet is to talk to Phil or Nathan.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
questions on JDM motors. jlonegro Newbies & FAQs 3 05-31-2007 02:44 AM
Urgent - Samco Turbo Inlet Hose on JDM motor? powerlabs Subaru Conversions 2 12-19-2006 11:13 PM
UTEC on JDM ECU thechase Engine Management & Tuning 15 10-10-2005 11:06 AM
ECUtek on JDM motor? mnkypsycho Engine Management & Tuning 1 06-15-2004 03:23 PM
did compression test on jdm motor ImprezaRSfan! Service & Maintenance 10 04-26-2004 05:53 PM
