Old 01-07-2001, 01:15 AM   #1
wrxsti
Member#: 493
1999 2.5 RS
Rally Blue Pearl
Question How sensitive is the speedometer needle??
I was installing Bankheists' blue guage conversion and did not manage to get the speedometer needle working smoothly. The speedometer would get stuck around 65mph and would not go any higher. So I removed the blue gauge conversion to see if the needle would move freely but it doesn't seem to fall back to 0mph as freely as before. It seems to hesitate a little on the way down.
After jiggling the speedo needle a bit the needle moves alot smoother.
My question is, does jiggling the speedo needle cause any damage?? Does it take much to screw up the calibration of the speedo needle???
wrxsti is offline
Old 01-07-2001, 04:17 PM   #2
wrxsti
Member#: 493
1999 2.5 RS
Rally Blue Pearl
Post
bump!!!
wrxsti is offline
Old 01-08-2001, 07:26 AM   #3
wrxsti
Member#: 493
1999 2.5 RS
Rally Blue Pearl
Post
bump....
wrxsti is offline
Old 01-08-2001, 07:34 AM   #4
jackwei
Member#: 233
Post
it's pretty sensitive, I hurt its feelings once
jackwei is offline
Old 01-08-2001, 08:40 AM   #5
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Post
wrxsti, when I put in my White face guages, I noticed the same thing. My Tachometer would get stuck around 3K, after messing with it for a while it got better, but not back to normal though Anyone know why this is?
Tkacik is offline
Old 01-08-2001, 12:52 PM   #6
The1one4ever
Member#: 1401
Post
yep, installing those damn color mods screwed up my meters. My speedometer has problems from 0-25mph. rpm jumps a little bit now and then. my gas meter won't tell me that my gas is low. The needle doesn't drop below the 1/4 mark at all. Only the clock and temp works hehehe
Solution? Thrash all the mods and just played around with the meters until at least they were moving They put everything back.
The[1]one
The1one4ever is offline
HTML code is On
just HOW sensitive is our transmission to mismatched tires ?? IllNastyImpreza Transmission (AT/MT) & Driveline 3 02-03-2009 10:00 PM
How sensitive is the ECU? Wylde Horses Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-16-2005 10:37 AM
any one know how long is the adjustable screw at the back on the HKS SSQV BOV starBug Engine Management & Tuning 3 06-04-2004 11:57 PM
3000 RPM and the speedometer needle BurntJamb Interior & Exterior Modification 0 04-23-2003 04:15 PM
How significant is the low rpm torque (below 3000 rpm) between the WRX & the 2.5 TS? falconfiend Newbies & FAQs 19 11-30-2001 09:23 PM
