Old 01-06-2004, 01:40 PM   #1
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
blue ridge pearl-sold
Default Which fly wheel to use?
I'am swapping in a ej20 into my RS(using old tranny) and was wondering if I need to reuse my old flywheel off of my ej25 or can I use the wrx's?
imprezaclipse is offline   Reply With Quote
Old 01-06-2004, 03:28 PM   #2
sprite1122
Member#: 43759
1999 2.5 RS
If your using your old tranny you can use your old clutch and flywheel setup. A wrx flywheel will not fit on your RS tranny
sprite1122 is offline   Reply With Quote
Old 01-06-2004, 04:14 PM   #3
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
You will need to upgrade your clutch though. The stock RS clutch is not strong enough to handle the power of the WRX engine. You may as well put in a lightened flywheel though.
Z
Zephyr is offline   Reply With Quote
Old 01-07-2004, 04:54 PM   #4
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Z
OK,but what if the clutch is brand new, would it not hold at all or just wear out faster?
Old 01-07-2004, 05:18 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not hold AND wear out very fast
Old 01-08-2004, 01:54 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
RS clutches simply were not designed to hold power. It may work for a little while, but it is doubtful.
-Jon
Which set of wheel to use for drag racing? txl146 Tire & Wheel 5 05-14-2008 02:33 PM
Which weight oil to use in this situation? armand1 Service & Maintenance 12 02-07-2002 03:16 PM
('93-'01) Which Transmission Fluid to use? 2yLiTe Impreza Forum 6 04-29-2001 01:04 AM
Which Brake Fluid to Use? silverSurfer Brakes, Steering & Suspension 21 02-03-2001 01:27 AM
