Old 01-06-2004, 02:55 PM   #1
serious
Member#: 22879
Default swaping a 02+ wrx complete front on legacy?
Hi all, what i was thinking is this; could i take a 02+ wrx front end crossmember, A arms and hubs along with suspension and bolt it to my 96 legacy?
Basically just drop the old stuff down and out of my car and lift the new stuff in is what i'm thinking. I know the new wrx has some additional support stuff for the very front of the car that the legacy doesn't, so this stuff is making me wonder.
Here's what i do know:
wrx crossmember (02+) will bolt to the legacy frame
bolt pattern of hubs is same
wrx steering rack is the same as in my 96
I pretty sure the top hats for the strut assembly are the same pattern
Anyone ever done this?
Thanks
Brent
serious is offline   Reply With Quote
Old 01-06-2004, 03:12 PM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
that would work fine for the mecanical end of the swap you still need to address the electrical part which takes about 3 times as long as the mechanical portion.
Z
Zephyr is offline   Reply With Quote
Old 01-06-2004, 03:18 PM   #3
serious
Member#: 22879
Does anyone know if the jdm sti 6speed hubs are any different (front hubs NOT back ones) than the normal wrx ones? I know the axles are different, thicker i think, but what about the acutally spline part on the hub itself?
Brent
Old 01-06-2004, 04:01 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Hubs are the same. Control arms are wrong if your clip is from a sedan. I think it complicates things even further by trying to swap a clip instead of just doing the engine, crossmember, and wiring.
-Jon
Old 01-06-2004, 05:14 PM   #5
serious
Member#: 22879
Well at this point it's already REALLY complicated so making it a little more so ain't going to change things much .
Brent
Old 01-06-2004, 06:08 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I disagree. My entire swap consisted of a transmission, rear diff, pedal assembly, and rear axle swap too. However, I did those back in November. Had I done all of that at the same time as my drivetrain swap, I would have saved maybe 1/3 of the time, but not enough for me to want to do it all at once. I was burned out once I got done and that was without dealing with the headaches I had doing the transmission.
-Jon
Old 01-06-2004, 06:25 PM   #7
serious
Member#: 22879
Cough, cough, when you have a lift, air tools and a cerified subaru tech at your disposal things happen pretty quickly.
Brent
02 WRX Complete Rear End, Front End GC8WSI Drivetrain 5 06-27-2009 02:19 AM
WRX Complete front brakes 02 $200 ConfusedRS Suspension/Brakes/Handling 6 09-09-2008 02:11 PM
02 wrx brakes front rear rotors pads bracket complete swap fastwrx25 SCIC Private Classifieds 5 02-20-2008 06:29 PM
02 wrx sedan front brakes complete swap 97LEGGT Suspension/Brakes/Handling 3 01-15-2008 12:35 AM
FS: NJ - 02 wrx COMPLETE front brakes $150 vsigma Private 'For Sale' Classifieds 4 03-25-2006 08:56 AM
