Old 01-06-2004, 04:03 PM   #1
serious
Member#: 22879
Default Hooking up a 6mt into a non 6mt car
Ok, i'm NOT asking how you hook up the dccd and that stuff. What i would like to know is how do you hook up stuff like the speedometer-backup lights-neutral swictch and stuff like this?
Does this stuff share the same plug as the wrx/legacy/every other subaru out there or is it different?
Brent
serious is offline   Reply With Quote
Old 01-19-2004, 11:54 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
"Cough, cough, when you have a lift, air tools and a cerified subaru tech at your disposal things happen pretty quickly.
Brent"
where'd your tech go?
Old 01-20-2004, 05:13 PM   #3
serious
Member#: 22879
Yeah, subaru tech as in trained to work and diagnos factory stuff, not modded stuff that has been imported . The six speed does come here now with the sti, but it is sooo new that i'm sure he hasn't even seen one up and close....yet.
Brent
Old 01-20-2004, 05:24 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Most dealerships, as of recently, didn't have a certified 6MT technician on hand. The stuff you have listed are no different than any other transmission. The backup lights and the neutral switch are both switches that get pressed when the transmission is in a certain position. If you do not have a WRX, then your backup and neutral switches might be different. In that case, I'll bet you can swap the switches from the old transmission to the new. I did this on my car for awhile; ie: I had a 2003 WRX transmission and I was using my 1996 L backup and neutral switches.
I don't think anybody has confirmed if you can use a mechanical vehicle speed sensor with the 6MT, but the speed sensors were interchangeable in the older years.
-Jon
Old 01-20-2004, 05:46 PM   #5
serious
Member#: 22879
Cool, at least that takes care of the speedo issue then. I'll be using a 02 wrx harness in my legacy to get things going. I plan to use the wrx guages too.
Brent
Any write ups on AVCS motor into a non AVCS Car? SINthetic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-04-2006 06:53 PM
is there a way to trick the ECU into thinking your o2 sensors are hooked up?? ammoniaman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-14-2004 01:16 AM
What wires do I splice into to hook up a turbo timer? NewbyScooby Subaru Conversions 0 05-27-2003 12:57 AM
What Color Wires To hook up Car setup installed in room SubaTubaru Car Audio, Video & Security 12 01-13-2002 07:51 PM
How to hook up PS2 in car? Chocobo Car Audio, Video & Security 6 12-27-2001 03:34 AM
