Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 01-06-2004, 03:27 PM   #1
BajaBratBoy
Member#: 51555
2004 Baja Turbo
Black Granite Pearl
Question Turbo Timer Harness question
I need to order a Turbo Timer and need an answer:
Does anyone know if a WRX STi harness will work on the Baja Turbo?
there are absolutly no hits for performance parts for the Baja Turbo on-line.
thanks in advance
BajaBratBoy is offline   Reply With Quote
Old 01-06-2004, 06:12 PM   #2
hatake
Member#: 34811
04 Baja T
Just curios - why would you need a turbo timer? It is a beaten-to-death issue in XT forum: http://forums.nasioc.com/forums/show...hreadid=457145
hatake is offline   Reply With Quote
Old 01-06-2004, 07:24 PM   #3
ryanvancil
Member#: 34063
Man, that really sucks for all those people who spent a hundred plus $$ on those stupid things and they never even needed one Not to mention all that extra gas they consumed while there car was just sitting there doing nothing for a minute or so! Over a year that could really add up!!
ryanvancil is offline   Reply With Quote
Old 01-07-2004, 12:16 AM   #4
BajaBratBoy
Member#: 51555
2004 Baja Turbo
Black Granite Pearl
The way I see it, the owner's manual doesnt require synthetic motor oil, but lots of people use it for "added" protection. And everyone agrees on driving a little extra to "cool down" the turbo after hard driving.
That Turbo Experiment also makes no sense. Take a close look at the graph. On the "Hot Side" lines, at 0 minutes why is the "idle" temp 825 degrees and the "Shutoff" line temp 775 degrees. If it was a true controlled test, they would both start at the same temp. How can the temp rise after you have stopped your vehicle to idle?
I agree that with the new technology, the "Shutoff" cooling has greatly improved. Is a Turbo Timer overkill? Maybe, but at less than $100, why not? It wouldnt hurt... plus I would most likely be setting the timer at 1min. As far a gas mileage goes, you idle 2 minutes at each red light. So it would be like hitting 1 - 2 extra red lights every day (assuming you start\stop your car 4 times\day). Gas mile is a non-issue.
Old 01-07-2004, 09:36 AM   #5
hatake
Member#: 34811
04 Baja T
I think it will be a nice extra care you can give to your investment -however, it sounds as if it comes at the expense of warranty denied - not sure on which parts, but I guess the warranty on turbo assembly and cooling system would be some of them. And that is a pretty darn expensive component in this car...
I was more thinking a way to ventilate/cool my garage: 90 degree heat in summer + red hot turbo sitting under my daughters' room = roasted kids room....
F/S: 08-09 WRX STi Turbo Timer Harness, 02-07 WRX STi Turbo Timer Harness...(pic) JunGdb Interior/Dressup/Audio & Security 0 08-16-2009 03:27 PM
HKS turbo timer harness and factory alarm problem UVAWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-02-2001 11:10 AM
HKS turbo timer harness markhost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-10-2001 04:47 PM
