Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 01-06-2004, 04:14 PM   #1
Member#: 12408
2006 Legacy GT
Default Stiff brake and clutch feel in cold weather?
I wasn't sure if this forum was the best place for this, but since it's a combination of a brake and clutch issue . . .
I was recently driving back from a ski trip where outside temperatures were in the range of -40C (-40F) . . . since we were cruising on the highway, I hadn't touched the brakes or clutch in a while. When we slowed for an exit, I noticed that the brakes required more effort (not spongy, firm), and the clutch did, as well. Could this be a result of the cold temperatures, and the hydraulic fluid either freezing or just becoming more viscous?
I have stainless steel brake and clutch lines, btw, and I'm using DOT5.1 brake fluid (stock clutch fluid, though). Maybe the stainless steel lines are less insulating than the stock rubber ones . . .
banman is online now   Reply With Quote
Old 01-07-2004, 11:04 AM   #2
Member#: 3258
2000 Impreza TS
I've never experienced firming of the brakes because of temperature, but the clutch definitely stiffens up when the weather gets cold. I've found that here in Calgary, in -20C and below my clutch starts off quite stiff untill the car warms up.
Ging is offline   Reply With Quote
Old 01-07-2004, 12:04 PM   #3
Member#: 1134
2010 Legacy GT Ltd.
It's VERY normal for brakes/clutch to feel more stiff in the cold. As far as your stainless lines, I wouldn't be surprised if that adds to the stiffness.... Remember that metal conducts heat (meaning hot/cold) very well, so that very well could contribute to a further drop in brake fluid temp, IMO.
Siper2 is offline   Reply With Quote
Old 01-08-2004, 03:37 AM   #4
Member#: 34
2005 WRX STi
World Rally Blue
Banman, I've driven 4hrs constant in winter but never that cold and my brake and clutch feel stay normal after the car's warmed up and running. I've only had SS clutch line this winter though, but nothing I can notice.
Ken is offline   Reply With Quote
people who commute on a motorcycle in cold weather and complain about being cold cnw Off-Topic 51 10-20-2009 02:09 PM
Brake and Clutch Pedal Sticking in Cold Weather alexk243 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-31-2008 09:52 AM
Stuck clutch pedal in cold weather? ASpec818 Transmission (AT/MT) & Driveline 4 12-26-2007 08:30 PM
('93-'01) Clutch "sticking" in cold weather Seeing StaRS Impreza Forum 11 02-11-2004 12:38 PM
Stiff Shifts in cold weather Ahzlon Transmission (AT/MT) & Driveline 5 12-04-2003 01:37 AM
