Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 01-07-2004, 12:00 AM   #1
Member#: 12176
2002 Geo Metro
Exclamation Zenki valve stems blow (no really!)
Just wanted to put out a warning/disclamer for anyone who is thinking about using *free*(see cheap) aftermarket valve stems. Again, this is MY experience. Many have had no problems with these... I did.
I just got a new set of tires and took them to Costco to get mounted. I decided to use the valve stems that came with the Zenki lugs I ordered from Revolutions Motorsports. I made sure and asked the guy if aftermarket stems were reliable, and he said "sure".
So this morning, halfway to work, I stopped at a gas station to get my tire pressures right. When I went around the car to check the pressures with the guage, 2 out of 4 stems DID NOT stop letting out air! I tried pushing in the needle thinking it was stuck, but the only thing that (kind of) stopped them was the cap.
Worried that I would end up with two flats by the end of work, I went back to Costco. The same guy was there, and when he saw me, before I said anything he says "the valve stems, right?"
He told me they were junk valve stems (good call) and to just use normal ones.
Even when he went to take off a non-leaking one, it BEGAN to immediatley leak when the cap was removed.
That is 3 out of 4 failure!
I'm bummed, because of the hassle, the lost money (I ended up losing a half day of work), and the quality of the product.
That is basically an excerp from a message I sent to Rev MS. I explained that I was in no way blaming them, just making them aware that a product that they are selling/including is potentially crap.
Again, maybe this is unheard of. But c'mon, 3 out of 4?!?!
blackbok is offline   Reply With Quote
Old 01-07-2004, 01:54 AM   #2
Member#: 25460
2002 WRX Wagon
wow that sucks
Nicotin2 is offline   Reply With Quote
Old 01-07-2004, 01:58 AM   #3
Member#: 5711
2004 STI
It just happens to me too and I freak out and I used a tweezer and just need to turn the horizontal thing in the middle across the needle itself and tighten it and it will fix it. It's no big deal. Go check it out and see if this fix or not on your car
calworld is offline   Reply With Quote
Any difference between STi valve stem seals and 2.0L WRX valve stem seals? CoolRex Built Motor Discussion 3 10-02-2009 10:57 AM
Ferrea 4G63 Valve Guides/Locks/Valve Stem Seals ITSME4G63 Non-Subaru Stuff 0 02-07-2007 11:02 AM
FS: (4) brand new Advan blue valve stems and valve caps D Money Wheels/Tires 6 11-13-2006 02:57 AM
BB$ owners, did chrome valve stems come with your wheels? Snappy Brakes, Steering & Suspension 2 04-26-2001 12:51 AM
6-star logo valve stem caps anyone??? Subie Gal General Forum Archive 8 06-27-2000 04:36 PM
