Old 01-07-2004, 11:19 AM   #1
TheMadScientist
Member#: 23717
2005 Big red
Default Why not use O2 instead of N2O?
Is there a reason why people use N2O instead of straight O2?
I would think that the O2 would be more effective. Is it price?
Thanks
TMS
TheMadScientist is offline   Reply With Quote
Old 01-07-2004, 12:04 PM   #2
AJT
Member#: 9312
Default Re: Why not use O2 instead of N2O?
Thanks
TMS
Too dangerous. One of the advantages of N2O is that the Nitrogen doesn't separate from the Oxygen until somewhere around 550 degrees Farenheit. Which allows it to be relatively safe and non flammable until it reaches the combustion chamber and achieves those temps.
-Andy
AJT is offline   Reply With Quote
Old 01-07-2004, 12:46 PM   #3
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
2 words... Boom! Ok, so it was one word... But pure oxygen is just ridiculously flammable and explosive just about anytime and anywhere. And yes, price would be an issue too if you're going to use liquid oxygen.
Old 01-07-2004, 12:57 PM   #4
cjbruce
Member#: 34114
2003 WRX Wagon
In order to get similar oxygen density you would need to use liquid oxygen, with all the nightmares associated with it. To get the same oxygen density with compressed oxygen gas, you would need to compress it to around 2000*0.6*14.7 psi = 17,000 psi. Not safe or feasible in a consumer automobile.
Edit: Pure oxygen is not flammable. It is, however, an excellent oxidizer. In the presence of heat and fuel it will rapidly increase the oxidation rate over air at atmospheric pressure--a fire will burn much faster and hotter.
cjbruce is offline   Reply With Quote
out-of-snow tow using hitch instead of hook Bluefoton General Community 16 12-15-2007 07:13 PM
This just in: Using 'z' instead of 's' in your name does not make you a bad-ass. Cosworth Off-Topic 39 12-15-2005 07:54 PM
Any real difference if i use 215 instead of 225 on a 17x17.5 rim MooseWRX Tire & Wheel 1 10-25-2003 06:48 PM
why a MY04+ forum instead of STi specific ? That isn't much of a "compromise".... SportyBry STi Forum Archive 12 09-14-2003 08:35 PM
Other countries use kw instead of hp? SK00Impreza General Forum Archive 7 03-01-2001 08:38 AM
