Old 01-07-2004, 03:30 PM   #1
driver
Member#: 4504
Default Do the 2004 WRX and 2.5RS use the same 5-speed transmission?
Hi. I was wondering if the 2004 WRX and 2.5 RS use the same identical 5-speed transmission?
Also I would like to know if the 5-speed in the 2004 2.5 RS is the same one as used in the 2001 2.5 RS.
Thank you.
driver is offline   Reply With Quote
Old 01-07-2004, 06:58 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
No. Turbos have a "Pull-type" clutch, others use a "Push-type" clutch
No. There have been changes in third gear and reverse (at least) as well as the bearing design in the Tail Housing and the center diff.
SubyTechMaster is offline   Reply With Quote
Old 01-09-2004, 03:05 AM   #3
driver
Member#: 4504
Thank you for your reply SubyTechMaster.
Do the EJ253/EJ251 and EJ257/EJ255 use the same size crank and rod bearings? ciper Built Motor Discussion 4 06-05-2009 07:01 AM
FS- 2000 2.5RS Coupe - Aspen White 5 speed UltraGucci VIC Private Classifieds 16 01-27-2007 02:58 AM
Is the center diff the same for the WRX and 2.5RS? battlewagon Transmission (AT/MT) & Driveline 21 08-22-2005 09:03 AM
Are WRX rotors and 2.5RS rotors the same size? Rock_Strongo Brakes, Steering & Suspension 5 04-11-2005 01:29 PM
Do the MY02 WRX and MY02 Forester use the same oil filter? Big_Hitter Texas Impreza Club Forum -- TXIC 4 11-28-2001 08:57 AM
