Old 01-07-2004, 04:05 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Brake Conversion
I'm gonna be doing an AWD swap soon, so I figured I would do some upgraded brakes too. I want to use something with good stopping power but that won't empty my pockets. I was thinking RS brakes in the rear and WRX brakes in the front? How does that sound. I think the swap has drums in the back right now. I know I can search to find out about the WRX rotors, but what about for the rear rotors? Any better options that could be suggested? Thanks.
Brent
scoobyimprza is offline   Reply With Quote
Old 01-07-2004, 07:51 PM   #2
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default i thought the rears on rs & wrx were the same?
your choice seems well placed for street & spirited driving. a good set of pads will do wonders. i put axxis ultimates (affordable) on wrx fronts, they have a nice initial bite , & immediately beg for better suspension.
tony
tbd is offline   Reply With Quote
Old 01-07-2004, 07:59 PM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
brembo rotors are cheap
subiekid is offline   Reply With Quote
Old 01-07-2004, 08:20 PM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Seriously? Are they better though?
Old 01-08-2004, 12:53 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The rotors and calipers are the same for the RS and WRX. The calipers are also the same in the front, however the caliper brackets and the rotor are larger for the WRX. I'm currently running WRX brakes all around, but I have been told that the factory pads suck and should be dropped like a bad habit. I have no complaints. Bias seems to be pretty good, but I haven't driven the car aggressively yet. If you want to have a bias that is shifted rearward, then you can go with the Outback H6 rear brake upgrade which utilizes RS/WRX calipers, H6 caliper brackets, and an 11.4" rotor.
Typically, rotors are not the problem. The OEM rotors work well unless you are using really aggressive pads. If you are in the market for rotors then I would look towards DBA.
-Jon
Old 01-08-2004, 01:02 PM   #6
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'11 X5 xDrive35i
'09 135i 6MT/'15 GTI 6MT
Does anything need to be done to adapt the parking brake to work with rear discs when moving from rear drums?
Geoff is offline   Reply With Quote
Old 01-08-2004, 01:03 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Yes, you need the parking brake cables and the flexible brake lines from a rear disc-equipped car.
There is plenty of information available regarding the brake swap itself.
-Jon
The same? H6 Rear brake conversion and 05 GT brake conversion efiniluvr Brakes, Steering & Suspension 7 11-12-2009 11:35 AM
Rear Drum brakes to Disc brake conversion ryking69 Brakes, Steering & Suspension 3 05-08-2005 09:16 AM
Rear Drum brake to Disc Brake Conversion scoobyimprza Brakes, Steering & Suspension 7 03-23-2003 07:07 PM
Rear brake conversion questions (kinda long) T'impreza Brakes, Steering & Suspension 23 03-16-2001 07:28 PM
Rear drum brake to disc brake conversion eicbal18 Technical Forum Archive 5 08-16-2000 11:23 AM
