Old 01-07-2004, 10:11 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default GDA steering rack fit a GC8???
any one fit a GDA steering rack into a GC8 yet?
im wondering if it will fit.....
h
supermoose is offline   Reply With Quote
Old 01-07-2004, 11:19 PM   #2
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
I'd like to know this too...I need a rack for my '94 jdm swap, and was curious if a GD rack fits a GC
annointed is offline   Reply With Quote
Old 01-08-2004, 01:34 AM   #3
Aspen_2.5RS
Member#: 3310
Ladies, Ladies........search......j/k lol
You'd have to modify the joints for the steering rack (make a hybrid). Someone on here did it. It would require cutting and welding.
I test fitted the GD rack in my 95L but found out the splines didn't match up, so we put the L rack back in.
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 01-08-2004, 01:55 AM   #4
supermoose
Member#: 9093
swap starr
hmm. i should reply with somthing crazy like i usually do on random noob posts........steering rack is a hard one thoug..hmm...lemme try:
to use GDA steering rack would be betterly benefitted by the use of a JDM S202+1 special steering rack, it is hybrid of rack in relation to the S2000 SS rack that is changable style 2.2 l-l to 1.7 l-l. u use button push and it are change teh correlation of steering wheel to rack movement. perhaps.
cool. that makes absolutely no sense.
h
Old 01-08-2004, 02:06 AM   #5
Aspen_2.5RS
Member#: 3310
Don't forget to put 2.21 jigawatts on it.
Cam
Old 01-08-2004, 02:59 AM   #6
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default i guess that means no?
http://forums.nasioc.com/forums/show...hreadid=471458
the only reason that gd rack was fanangled onto a gm body was because it was an sti quick rack. other than that, i'm not sure if it would be worth the hassle.
tbd is offline   Reply With Quote
Old 06-30-2004, 05:48 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Does anyone know what the actual spline counts are? This is something I'd like to try to do, too (well, in my case, GDA into BD). I'm not big on the cutting and welding thing, though.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-01-2004, 02:03 AM   #8
serious
Member#: 22879
Here's what i know: I have a 03 jdm wrx crossmember in my legacy. I have a steering rack from a 93 turbo legacy in the wrx crossmember.
I tried the wrx (02 usdm one) and the steering linkage spline was different as someone else mentioned. So me being me i took them both apart to change the splines as they looked identical.
that's what i got out of that! Subaru got creative on us, so don't bother trying to exchange the spline in the steering rack.
You could get a wrx steering column which i'm going to try this as soon as this guy gets me some pics. Or you could make a hybrid steering linkage with legacy spline on one side and wrx on the other.
As far as the o2 wrx steering rack fitting, it looks identical to the 93 one, so i think it would.
The power steering lines are some what different though. The steering rods that come out of the power steering rack to the hubs are identical in length compared to the older track versus the newer 20mm wider track.
B
serious is offline   Reply With Quote
Old 07-03-2004, 04:43 AM   #9
tbd
Member#: 15322
1995 gf wagon
Default WRX GD rack
sedan.
spline count: 36?
pics here, study them yourself.
http://community.webshots.com/album/158893975ZDUlZL
The pins I suggest drilling out are on the plastic cush drive in the center. the U-joints at either end do not appear to be easily removeable.
tony
Old 07-03-2004, 01:57 PM   #10
OvenMitts
Member#: 46278
96 Impreza
"brighton"
So if you've got the GD rack and steering column, what else would have to be modified to fit the GC.. anything?
OvenMitts is offline   Reply With Quote
will an 07 steering rack fit on a gc8? ralliboi Brakes, Steering & Suspension 2 05-25-2008 09:06 PM
usdm steering rack fit in earlier imprezas? petawabit Brakes, Steering & Suspension 5 12-06-2004 01:19 PM
Will a USDM STi steering rack fit on a WRX wagon? redobs Transmission (AT/MT) & Driveline 8 07-29-2004 04:04 PM
Will the JDM STi Spec C steering rack fit in the USDM 04 STi? Mach5WRX Brakes, Steering & Suspension 7 09-21-2003 12:20 AM
STI steering rack ... fit "03 WRX Wagon? makofoto STi Forum Archive 9 05-27-2003 01:10 PM
