Old 01-08-2004, 12:20 AM   #1
ctwrxwagon
Member#: 22724
2002 Bah, Sold My
404whp/414wtq Wagon :(
Default I think my car is dead, jim.
Well, here is a quicky for ya'll -- help me out in my stupidity please.
First let me explain the car.. 2002 WRX Wagon with 43,000 miles on it,5 speed, gone through one oem clutch already, on the second one now,
I've done a FP18G Turbo Swap, Downpipe, Uppipe, Intercooler Hoses, Catback, unichip stage 3, have a stereo in it as well, turbo timer what have you;
i know some of that stuff is irrelevant; maybe it could be something electrical making the alternator squeak or something. I also just did a brake job ~600miles ago (just new pads; grease was put in all the right places).
Anyway -- on to my problem. I've had the car as my daily driver since August '02; haven't had many issues with it; it does what i want when i want, etc. Tonight, I got on it a bit hard going up a hill, at first i thought the clutch was slipping, but no; it wasn't. The car took off, leaving a little bit of tire marks on a sandy road. I pull into a driveway to turn around and i hear a screetching/moan,
which, I believe, is coming from the driveline. When I first hear the noise; the shifter got quite warm/hot, and cooled off immediately; I went to shift into gear and no problems at all, i checked for smoke/smells none at all, checked all seals on the diffs and gear box, bolts, nuts what have you; no leaks as far as i can tell. I believe it isn't a wheel bearing because it isn't consistent; for instance wouldn't it make noise as the car travels
and brakes? I doubt it is the power steering as well; due to the fact that the resevoir is
full and the noise only comes on while traveling foward or backward witht he wheel FULLY
turned to either side.
I am thinking its either the axles or something in the diffs? Maybe a screwed up cross-pin;
chunked spider gears? or what?? I really can't figure it out; if it was an axle wouldn't the
car wobble a bit and then go ahead and pull to one side and make noise when going forward
irregardless if i was turning or not. Maybe it's the lug nuts (since I know at least on
my mustang its a wise idea to re-tighten them after 500miles or so (after you do a service
which requires the wheels taken off) but I checked that as well. Maybe a CV Joint??
Anyone happen to have a answer for me? Or at least something else to look at before i break
out the $$ for a subie tech to take a peek?
Thanks Much & Best Regards
-G
ctwrxwagon is offline   Reply With Quote
Old 01-08-2004, 10:19 AM   #2
mch
Member#: 30039
2002 wrx wagon
dirt slvr
When you are making a turn with the steering wheel as far as it will go, you are placing maximum stress on the car's differentials. This is because all four of your wheels are all travelling greatly different distances.
This is no big deal between the front wheels as there is an open diff there BUT the link between the front and rear is dealing with a significant difference in rotational distance (hence the term differential).
Your "problem" will occur in a slow speed, VERY tight turn with good traction. Usually it is accompanied by a slight hot material (diff fluid?) smell as well.
If you make the same turn on a sand/ gravel/ snow or otherwise slick surface, wheels will slip to reduce the back pressure on the system and all will seem fine.
If the car starts to make these noises under easier driving conditions, then it's time to get it checked out.
Good luck.
mch is offline   Reply With Quote
Old 01-08-2004, 12:58 PM   #3
ctwrxwagon
Member#: 22724
2002 Bah, Sold My
mch -- come again? Sorry I'm a bit out of it right now due to the medication I am on from the surgery i just had -- but anywho -- I'm thinking it might be a cv joint.. because the noise occurs (popping) whenever the wheel is turned all the way to lock on either side.. and only when i'm going slowly. I think the shifter heated up because there might be something in the driveline which is putting massive stress on the front end.
Now.. the link between the two would be the driveshafts? Could it be possible that the U-Joint could have gone out? I have yet to get this car up on a lift; however I do know that driving, braking, steering, acceleration and deceleration have NOT been affected (knock on wood).
Thanks Much for Your Reply!
-G
I think my AP2 is dead MB38 AccessPort 20 09-21-2008 03:49 AM
I Think My Utec Is Dead? RickDaTuner UTEC 1 05-05-2006 09:30 AM
I think my motor is dead Thrilryder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-23-2004 11:09 AM
Need help, think my unit is dead... can i play with yours? blitz WRX-pilot Southern California Impreza Club Forum -- SCIC 9 04-30-2004 04:37 AM
('93-'01) My website is dead, Jim. stimpy Impreza Forum 6 07-05-2001 10:37 PM
