Old 01-08-2004, 10:08 AM   #1
SprintZagato
Member#: 43142
2003 2004 Impreza
Java Black
Default Friction Noise When turning Steering Wheel
Don't know if this is the right forum to put this problem. Anyway, I hope my poor English can express my WRX's problem clearly.
My WRX is 2004 model. Recently, when I turned the steering wheel, I heard some kind of "friction Noise" under the hood. It's especially apparent after parking for a long time(like overnight)
Did anybody haev the same pronlem before?
SprintZagato is offline   Reply With Quote
Old 01-08-2004, 11:02 AM   #2
dcoty
Member#: 3149
01 V7 GC/R32 sky
If it feels crunchy it might be due to the power steering fluid/pump. I have the same problem, it makes a vibration in the wheel though when i turn.
Dan
dcoty is offline   Reply With Quote
Old 01-08-2004, 01:36 PM   #3
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I know the sound your talking about!
When I told the people here they thought I was going nuts
It's like a Pumpish sound.. I mean like 3 weeks a ago I went to pull up to the pump and I had to turn my wheels to the right.. lol a guy standing at the pump turned around and looked at my car.. I dunno I never heard it from the outside..
I might Mic my car up again
SubaruImpreza_power is offline   Reply With Quote
Old 01-08-2004, 01:38 PM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Dan
Also Check the Fluid Levels.. If the Fluid is low like mines and I try and turn the wheel right after I start the car it's like I have No Power Steering until about 3 Seconds later it's all fine, But I do need to add fluid If it's like my car it will be DEXRON ATF FLUID TYPE II or III.
Old 01-09-2004, 10:50 PM   #5
SprintZagato
Member#: 43142
2003 2004 Impreza
Java Black
I took the car to chasis garage. The crunchy sound was gone. Technician and I couldn't find any noise when turnng steering wheel. After I came home, the crunchy sound appeared in the next morning.
I have checked the pump oil level. It's between max and min.
Does anyone with another suggestion??
SAD, I thought Impreza is Bullet proof engineering...
Old 01-10-2004, 12:18 AM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
When the car is at normal temp read the power steering pump dipstick If it's like you said then add some fluid to it.
Trust me the engine will last, I have over 132K miles on mine and it still runs great and no pump problems.
Noise when turning steering wheel to the right only aifan27 Brakes, Steering & Suspension 3 08-15-2009 02:31 AM
engine surges when at idle when turning steering wheel YANG_STI Service & Maintenance 9 09-03-2008 03:55 PM
front passenger noise when turning steering wheel almost all the way? ASpec818 Brakes, Steering & Suspension 1 01-13-2008 12:28 AM
Thumping sound when turning steering wheel at a stop? ImportVenom Brakes, Steering & Suspension 7 11-07-2003 08:58 PM
creaking noise when turning the wheel mattmounce Brakes, Steering & Suspension 5 04-15-2003 10:28 PM
