Old 01-08-2004, 12:16 PM   #1
Chewy-WRX
Member#: 19426
2002 WRX Black
I luv the Ice Gnomes....
Default Switching from 225 to 215 tires
Hey guys, I'm currently using 225/45 Falken Aziens on 17"x7.5" Rotas.
I want to swtich to a narrow tire so I have less traction (so I dont kill my tranny so quick)
If I switch to 215 what is the correct tire dimension? 215/40? 215/35? 215/45?
Thanks
Chewy-WRX is offline   Reply With Quote
Old 01-08-2004, 12:41 PM   #2
sjw
Member#: 44905
'04 wrx 5-door
dirty
45 is closest...
sjw is offline   Reply With Quote
Old 01-08-2004, 01:56 PM   #3
Benjamin Tang
Member#: 4496
2009 Forester
red
my brain is going fuzzy... someone correct me if i'm wrong.
i thought the proper plus1 sizing for the wrx is 215/45/17, and then plus2 was 225/40/18? so if i were to use a 225/45/17, would that mean the tire is too tall?
Benjamin Tang is offline   Reply With Quote
Old 01-08-2004, 02:21 PM   #4
YinUCSD
Member#: 44945
06 LGT wag
on paper, 225-45-17 overall wheel diameter remains closest to stock 205-55-16. just do the math. but it just depends on the tire manuf how wide (and, thus, how tall) the tire actually is. on paper, 215-45 is ~0.4" short of stock diameter and 215-50 is 0.4"-0.5" taller than stock, but SOA recommends 215-45 when going to 17" wheels. methinks to avoid rubbing, and to use a smaller diameter rather than a larger diameter.
YinUCSD is offline   Reply With Quote
Old 01-08-2004, 02:24 PM   #5
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
Barry is offline   Reply With Quote
Old 01-08-2004, 03:12 PM   #6
doobie
Member#: 6570
04 WRXSW
9.3 TRB0 CNV
Helpful site you'vs found there!
doobie is offline   Reply With Quote
Old 01-08-2004, 09:20 PM   #7
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
That's about 5% less contact patch area between 225 and 215 tires. I doubt it will make any difference.
Craig
c_hunter is offline   Reply With Quote
Old 01-08-2004, 10:04 PM   #8
fliz
Member#: 30342
If you really want less traction, switch to a 60,000 mile tire with rock hard rubber. Your traction is much more about how sticky your tire is than how wide it is. The increased contact patch mainly helps temperature build-up in the tire. And at 5%, I don't think it makes any difference.
The only reason I could see to switch is rubbing, it might be easier to find a cheap tire in 215/45/17, and the slightly smaller diameter reduces the torque on your drivetrain components.
fliz is offline   Reply With Quote
Old 01-08-2004, 11:28 PM   #9
mch
Member#: 30039
2002 wrx wagon
dirt slvr
Tire contact SIZE (area) is a function of tire pressure not width.
Tire contact SHAPE is a function of tire width.
Traction is a function of the mechanical interlock between the tire and the road surface. Less deformation of tire surface (i.e. harder tire) = less traction as noted above.
have fun.
mch is offline   Reply With Quote
Old 01-11-2004, 01:17 PM   #10
Chewy-WRX
Member#: 19426
2002 WRX Black
mch and fliz,
Much thanks.
Does anyone want to recommened a good "rock hard 60,000 mile tire"?
Old 01-12-2004, 12:59 AM   #11
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
Craig
And also the pressure on that contact patch will be about 5% more as well. Friction is a function of normal force, so in a straight line, the traction would be almost exactly the same.
mtb_dude is offline   Reply With Quote
Old 01-12-2004, 04:30 AM   #12
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
but tire wear would be increased.
nhluhr is offline   Reply With Quote
Old 01-12-2004, 10:23 AM   #13
Orson
Member#: 25254
2003 WRX wagon
Like was suggested, find a less grippy tire - that will make more of a difference than any sizing changes. The least grippy tire will almost always be the cheapest all-season tire, so shop based on that criteria.
Orson is offline   Reply With Quote
Old 01-12-2004, 11:55 AM   #14
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
true dat!
Old 01-12-2004, 04:24 PM   #15
Chewy-WRX
Member#: 19426
2002 WRX Black
Suggestions anyone? thanks.
Old 01-12-2004, 05:56 PM   #16
rexster
Member#: 22863
2015 WRX Premium CWP
buy a cheap set of used stock wheels and stock RE92 tires. Put them on before drag racing. Take them off after. That way you'll have good drag times AND a car that handles well (when you're not on the way to or from the drag strip).
Or, if you really want to run a low traction all the time, just browse the tirerack website for all seasons in that size. In general you can go by the tire's UTQG rating. The higher the number, the harder the rubber, the worse the traction will be.
rexster is offline   Reply With Quote
Old 01-12-2004, 08:43 PM   #17
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
I'm not much of a drag racer, but I've heard that RE92s with over 30k miles on them make excellent tires for drag racing.
exhaust opinions plz (looking to switch from cobb to g200) mookies Newbies & FAQs 12 07-01-2009 08:16 PM
Convice me to switch from 17" to 16"/15" tires Gabriel~ Tire & Wheel 11 09-28-2008 12:34 PM
Switching from Cingular to Verizon... How to keep my number? brucelee Off-Topic 16 04-18-2007 11:33 PM
Subaru WRC switch from Pirelli to BF Goodrich Tires for 2007 NYCshopper News & Rumors 48 01-06-2007 11:27 AM
Rubing issues aside..whats the big diff. between 225 and 215 tires? dorifto88 Brakes, Steering & Suspension 2 01-03-2003 01:54 PM
