Old 01-09-2004, 01:44 AM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default Will different wheel widths work on AWD?
Are there any disadvantages to having TE37 17X8" wheels on the front and 17X9" on the back? Would there be rubbing in the back? Since they don't turn I can't imagine it.... I ask because someone is selling a set but they are 8 and 9 inch wheels.
essogas is offline   Reply With Quote
Old 01-09-2004, 07:38 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I think as long as you put the same tire on all rims, you should be OK. What are the offsets?
There was an article in SCC a while back about some Japanese racing Impreza that had different sized wheels, front and rear, but the same size tires. This was done to help stiffen the sidewall on one end of the car, I just don't remember if the wider wheels were in the front or rear.
Old 01-09-2004, 09:24 AM   #3
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Kevin
Red Rocket is offline   Reply With Quote
Old 01-09-2004, 01:12 PM   #4
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
The wider wheels were on the front of the car to gain better cornering/turning ability. I forget which Impreza it was, but I read that article too.
K
rankink is offline   Reply With Quote
Old 01-09-2004, 05:05 PM   #5
essogas
Member#: 35703
2004 WRX STi
TE-37 17"X8 and 17X9 with 44 offsets. Will this work or not? I will tell you know so the bidding war can begin but there is a guy selling a set of Volks with this set-up on ebay. It caould be a very good deal and I'm certainly in the market right now for some volks.
Old 01-09-2004, 05:40 PM   #6
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I went and found the auction. How do you know the offset and that the bolt pattern is correct.
Yes it will work. You want the 9" wide ones in the front, 8" in the rear. 245/40-17 is the tire size to run, front and rear.
I run 17x9" et50 front, 17x8.5" et48 in the rear, with 255/40-17 tires. Seems to work well.
Kevin
Old 01-12-2004, 02:06 PM   #7
bluelinescooby
Member#: 48881
2009 1125CR
1996 Neon ACR
K
The car was the Bozz Evo VI. The front wheels are an inch wider than the rears, but they use the same size tire. It does exactly what rankink said.... squares up the sidewalls on the front to help turn-in and rounds the sidewalls in the rear to give a progressive breakaway, to paraphrase the article. Little off-topic, but I thought I'd throw it in.
bluelinescooby is offline   Reply With Quote
What torque converter differences are there? Will Phase 1 TC work on a Phase 2? ciper Transmission (AT/MT) & Driveline 1 01-14-2010 01:07 AM
Will 00 rs axles work on a 95 awd L? mcu81 Transmission (AT/MT) & Driveline 2 02-06-2005 08:35 AM
Will 215/60-16 work on oem WRX Wheels? Takashi Tire & Wheel 2 01-15-2004 02:03 PM
Will Different Tire Sizes Harm the AWD?? WRXcellent Tri-State Area Forum 10 06-06-2003 06:26 PM
will a +45 offset work on an 18X7.5 wheel? scootr Brakes, Steering & Suspension 13 03-17-2001 08:37 AM
