Old 01-09-2004, 11:37 PM   #1
spike
Member#: 6580
Default toyota engine problem, need help.
I know off topic is for non technical topics, but I don't know where else to put this where it will get viewed quickly. My friends 2000 Toyota Corolla is having problems and she is stressing. The car only has about 40K on it, and the warranty just expired. I am just learning about cars with my WRX, so I wasn't totally able to help. Her engine/car shudders at idle and continues until up to speed, and doesn't accelerate as it used to. Her Uncle thought maybe it was the spark plugs, so he changed them. That didn't help, so she took it in to the dealer. They told her that it was probably the spark plugs, and when she told them that they were replaced, they said she needed to use factory plugs and that her uncle put the wrong plugs in. They gave her the run around for a while with various calls. Next they told her that her fuel delivery system in each cylinder is broken. The new part has to be ordered and it will cost $1000. I looked up possible causes and spark plugs, spark plug wires, and fuel system problems came up. Just wondering if anyone has any feedback from what I have described above. I have learned a lot of technical information on this site, so this is the first place I thought of to ask. Thanks in advance.
chad
spike is offline   Reply With Quote
Old 01-09-2004, 11:50 PM   #2
Volvo740Turbo
Member#: 25924
2004 350z
PPW
Yea my girlfriends car has the same problem, but its a 95..... vibrates while idling.... any help? JANQ!?
edit: I was thinking engine mounts?? anyone... bueller?
Volvo740Turbo is offline   Reply With Quote
Old 01-10-2004, 12:05 PM   #3
Nightwing
Member#: 45007
98 Forester 2.5 S
I think the big problems are as follow:
1) It's a corrola (and I'm a Toyota Fan so...don't think I hate Toyotas)
2) A chick drives it every day
3) IT's a corrola
Nightwing is offline   Reply With Quote
Old 01-10-2004, 12:08 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Check engine light on?
PM: Murray
he is a toyota tech.
Jay
Old 01-10-2004, 12:17 PM   #5
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Before you spend big bucks at the dealer, I would do the following in this order:
- Check to make sure the new plugs are really the right ones (don't have to be factory-spec, just the right temp, gap, etc). Make sure they are firmly seated and the plug wires firmly attached in the correct order.
- Then check carefully for loose vacuum hoses (basically check every hose in the engine compartment).
- If the plugs are OK and no loose hoses, run some fuel system cleaner/water remover through it and fill it with fresh gas. Also change the fuel filter.
- If that does not work, change the plug wires.
That's all I can think of for now.
Mike Wevrick is offline   Reply With Quote
Old 01-10-2004, 12:26 PM   #6
pnilly
Member#: 26088
out of your
system
try one of these
www.vvti.net - Corolla forum
www.corollacustomz.com - Corolla forum in Canada
www.club4ag.com - Older Corollas forum
www.corolla-racing.com - Corolla forum and enthusiasts site
www.corollaforums.com - Corolla forum
www.northeasterntuners.com - Site for Corolla enthusiasts in the northeast
www.2003corolla.org - 2003 Corolla forum
www.corollaclub.nl - Corolla club in the Netherlands
pnilly is offline   Reply With Quote
Old 01-10-2004, 12:28 PM   #7
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
my parents have a 99 corolla with 50k miles. its never had any problems. they just put oil and gas in it basically.
ZoomnWRX is offline   Reply With Quote
Old 01-10-2004, 12:33 PM   #8
spike
Member#: 6580
Thanks for all the replies, that helps a great deal. Yes, the check engine light is on.
chad
Old 01-10-2004, 12:45 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
can you have the codes read?
that would help imensly.
Jay
Old 01-10-2004, 12:55 PM   #10
footypaul
Member#: 9570
doesnt autozone read codes for free now?
footypaul is offline   Reply With Quote
Old 01-10-2004, 12:58 PM   #11
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
yes and so does checker
DanO
Merdock777 is offline   Reply With Quote
Old 01-10-2004, 01:03 PM   #12
Paul Sakai
Member#: 2513
2000 RS Coupe
Silverthorne
Engine mounts could be weak, was the first thing I was thinking
Paul Sakai is offline   Reply With Quote
Old 01-10-2004, 01:28 PM   #13
Mike Wevrick
Member#: 24654
1957 Taggart Comet
How would engine mounts affect acceleration?
Definitely get the code read; that should identify the problem.
Old 01-10-2004, 01:34 PM   #14
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
he is in CA, CA law AFAIK restricts auto parts stores from reading/supplying codes.
Old 01-10-2004, 01:39 PM   #15
Paul Sakai
Member#: 2513
2000 RS Coupe
Silverthorne
It wouldn't affect it too much, but if you have a broken engine mount you're engine sways alot and you would lose torque to the drivetrain.
Old 01-10-2004, 02:53 PM   #16
wrigh003
Member#: 13997
The engine mounts are probably not it, as I drove my old Accord for thousands of miles with toasty engine mounts. All that would account for would be a vibrating steering wheel at idle, I think. Power shouldn't be affected too much.
<what everybody else said>
40K miles, look at those plugs again. If they're not the right temp/gap, that's probably it. If they are, check to see that all the hoses are hooked up tight and right. If they are, get that code read and go from there. It might be something as simple as a gummed up o2 sensor forcing the car to run rough. Fuel system cleaner might help, too.
</what everybody else said>
wrigh003 is offline   Reply With Quote
Old 01-10-2004, 03:35 PM   #17
spike
Member#: 6580
Unfortunately, she is in Seattle, so I can't get my hands on the car. She heard back from the dealer and they said one of her fuel injectors is broken. They recommend replacing all four, which is $172 per cylinder, and ~$250 labor. Thanks for all the input, again, it was very helpful.
chad
Old 01-10-2004, 03:45 PM   #18
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
probably just bad wires as someone stated.
mattjk is offline   Reply With Quote
Old 01-10-2004, 04:16 PM   #19
Mike Wevrick
Member#: 24654
1957 Taggart Comet
If its 1 fuel injector, why do all 4? I would just do that 1 and see what happens.
Also, fuel injectors should not go bad after only 40 k (The ones in my 95 legacy have never even been cleaned in 170 k)
Old 01-10-2004, 04:49 PM   #20
pnilly
Member#: 26088
out of your
system
Tell her to take it to autozone to have the codes read. If she flirts a little, maybe one of the guys there can fix it for her.
Old 01-10-2004, 04:51 PM   #21
thesmokingman
Member#: 17751
That depends on your refill policy and the quality of gas used.
Let it run too low and you risk contaminants getting thru. Use cheapass gas and you risk more contaminants and other things associated with cheap gas.
My sister-in-law, who is notorious for using Arco, which btw is crap, and always runs it to the bottom. Her injectors on her 99 Civic clogged after 2-3 years of usage. The techs told her to stop using Arco. Funny.
thesmokingman is offline   Reply With Quote
Old 01-10-2004, 04:53 PM   #22
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
When they're replacing the fuel injectors, have them saw the ends off to make them giant 740cc injectors. That should really help her when she starts to put down wheel-smoking torque later.
rogue is offline   Reply With Quote
Old 01-10-2004, 05:35 PM   #23
Mike Wevrick
Member#: 24654
1957 Taggart Comet
I usually buy el-cheapo no-name gas and fill at 1/4 tank. I do agree about running too low; I never do that.
Old 01-10-2004, 05:40 PM   #24
The Enemy
Member#: 12851
She needs a new high flow fuel pump too then!
The Enemy is offline   Reply With Quote
Old 01-11-2004, 05:10 AM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
did you try cleaning the MAF sensor yet, does this car have a K & N air filter in it??
Jeremy
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
engine problems..need help.. fosingwo Subaru Conversions 5 10-27-2006 03:09 PM
Engine problems - Need help ASAP! Soon2BturbodRS Normally Aspirated Powertrain 13 06-25-2005 06:08 PM
Engine Problems Need Help!!! RSimport Normally Aspirated Powertrain 7 06-10-2005 05:00 PM
engine problems..need help gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-10-2005 09:00 PM
