#1 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
So yes, today I tried them out. Took apart a ej18 left over at EddyRS's house and tested how the EJ20 heads will work with it. Good learning experience for me, and heres what I learned:
A) The EJ18 heads suck. They have far smaller intake holes, and inky dinky ports and valves... B) Everything bolts up perfect. The headgaskets from the EJ20 head work perfect on the EJ18 block, and allow the coolant channels to get through properly. And on a side note, the ej18 head channels are far smaller than the ej20 (no surprize). Even the coolant aluminum channel on top uses the same bolt locations as the ej18 one... C) Despite the fact that everything bolts up fine, there is a serious problem. The valves. The EJ20 valves are so much larger, and spaced so differently that they will most definatly hit the EJ18 pistons at the valve relief cuts in the piston This means that aftermarket pistons will be required for the EJ20 heads to work with the EJ18 ![]() Here are some pics: http://community.webshots.com/album/110209915vXVzdU If anyone has any questions or comments, feel free to post.
#2 |
Member#: 47597
Vehicle:1997 ///M3 '93 Impreza |
Isnt the EJ18 a SOHC while the EJ20 is a DOCH? Or at least thats how it looks in the pics, and if it is how do you set up the belts?
#3 | |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
Good info, I think you have me convinced on what I want to do. Brent |
#4 | |
Member#: 2272
BAIC
#5 | |
Member#: 2272
BAIC
#6 |
Member#: 3357
Vehicle:2002 WRX Black |
pretty cool experiment I would have loved to hear how that work out to be a bolton operation. Eh that sucks..
Hey if you want i have a ej20 short block for $500 that would make you an N/A ej20 but probably be pretty interesting to see how it runs in N/a form. Good Luck anyway. Imprezd~ |
#7 |
Member#: 2272
BAIC
Naw, its ok, im getting a whole 260ps closed deck EJ20G including turbo among other things for not much more than that
So im good ![]() |
#8 |
Member#: 2181
SCIC
Vehicle:2008 SpecB DGM |
Your EJ18 heads have one exhaust port or two? I can't see them in the pix.
Just curious, I have a P2 EJ18 with twin exhaust ports and wonder if there would be such a difference with the EJ20 heads. |
#9 |
Member#: 24956
They're twin ports.
#10 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
... well that and the engine mangment not sure how the ecu would deal with the smaller DOHC timing belt wheel on the cam sensor
want to sell that turbo ... please? -j |
#11 | |
Member#: 2272
BAIC
#12 |
Member#: 177
NWIC
yeah yeah the td05...will swap you for a nice vf-10
#13 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
In you case the lower compression pistons...if made should fix your problem....go to www.jepistons.com and check out what some custom pistons will run you. I was looking into it. but you will need measurements from your engine.
Take it easy, Micah |
#14 | |
Member#: 2272
BAIC
#15 | |
Member#: 2272
BAIC
#16 |
Member#: 10441
BAIC
Kosta- Long time no see. If you need a hand turning wrenches on your swap, let me know. I'll be back to CA around 21Jan.
| Thread Tools | |
| Display Modes | |
| Ej20G heads on an EJ18, will things get banged up! | turboL | Built Motor Discussion | 25 | 06-21-2011 10:24 AM |
| EJ20 heads on an EJ22t block? | sheepdog | Built Motor Discussion | 3 | 08-04-2008 08:31 PM |
| comp of sohc ej25 heads on a ej18 block? | josh...just josh | Subaru Conversions | 2 | 09-26-2006 09:53 PM |
| EJ22 heads on an EJ18 | Cstmboxermotorsports | General Community | 9 | 12-23-2005 06:46 PM |
| Serious hypothetical question: What is needed for EJ20 heads on an EJ18 block? | Kostamojen | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 01-12-2004 01:42 AM |
