Old 05-22-2000, 09:32 AM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Question Help! I think my AC is broken!
I turned on the AC in my MY00 RS for the first time this weekend to battle the 100 degree heat in the Bay Area. The car was sitting in the garage all day and wasn't in the sun. So on the way to drop by my parent's house I turned AC. I kept my speed low so not to keep to circulate the oil in the AC system. Unfortunately, it never got cold. I got more relief rolling down the window. Has anyone else had this problem? Am I doing something wrong? I'd like to know before I make a trip to the dealer.
HomerJay is offline
Old 05-22-2000, 09:35 AM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
You kept your speed low to not circulate the oil in the AC system? What does that mean?
RidinLow is offline
Old 05-22-2000, 09:35 AM   #3
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Post
I found in my XT6 that i need to get on the gas initially to get the A/C to kick in. After that it doesn't matter, and it's really cold (for 12 years old I'm very happy with the A/C in it)
-mike
Paisan is offline
Old 05-22-2000, 09:39 AM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Since the AC compressor is driven by the engine crank, more engine RPMs should get it to work more efficiently, especially if you have an underdrive pulley.
~G
RidinLow is offline
Old 05-22-2000, 10:03 AM   #5
HomerJay
Member#: 1135
2005 WRX WAGON
Post
The manual says to run the car at idle or low rpms when you first start using the AC to circulate the fluids in the AC system. I would think after 15 minutes of driving, the AC would get cold but it didn't. Looks like a trip to the dealer for me.
HomerJay is offline
Old 05-22-2000, 10:09 AM   #6
bluesaint
Member#: 876
Post
its the connection the engine comparment.. its loose.. i had the samething happend to me after i try turning it on
bluesaint is offline
Old 05-22-2000, 01:31 PM   #7
Steve00RS
Member#: 954
Post
Check to make sure the AC compressor is even plugged in. There is probably a connector hanging next to the AC compressor. Chances are, the boys at the dealership werent paying attention when they prep'd it. Mine was the same way. They didnt bother to put the fuse in for my interior lighting either.
I dont take my car there anymore.
Steve
Steve00RS is offline
Old 05-22-2000, 01:33 PM   #8
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
I question the A/C in my 99 2.5GT sedan also. The compressor DOES come on, but the AC never really gets cold. It's cool at best. I know the AC in my DSM will freeze my ba| |s off.
I plan on taking mine to the dealer.
Kev
Force[FED] is offline
Old 05-22-2000, 02:10 PM   #9
Paisan
Member#: 197
'14 Touareg TDI '14
Post
Then again I have REAL freon in my '88 XT6... Yippie.
-mike
Paisan is offline
Old 05-22-2000, 04:39 PM   #10
samurai
Member#: 696
2005 WRX STi
Post
I agree with the majority.. Check the A/C connector plugs above the compressor unit. When we first test drove the car, we checked the A/C and it didn't seem to work.. We popped the hood and lo and behold, the plug was disconnected..
Tim
samurai is offline
Old 05-22-2000, 05:14 PM   #11
HomerJay
Member#: 1135
2005 WRX WAGON
Cool
"Coolness" thanks for your help guys. I'll try it when I get home tonight(carpooled today). I'll let you know if that was the case.
HomerJay is offline
Old 05-23-2000, 12:11 AM   #12
HomerJay
Member#: 1135
2005 WRX WAGON
Unhappy
Thanks for the tip Bluesaint. Is this something quick I could do, or is it something the dealer should do?
HomerJay is offline
Old 05-23-2000, 10:18 AM   #13
HomerJay
Member#: 1135
2005 WRX WAGON
Cool
Hey Steve and Samurai, thanks for the tip. That did the trick. My damn trunk monkey failed me . I guess I'll get a new monkey. Thanks again!!
HomerJay is offline
HTML code is On
I think my AP is broken? RMX AccessPort 2 05-21-2010 09:32 PM
HELP i think my compter is Borked pistoffjstr Off-Topic 6 05-17-2006 07:49 AM
NEED HELP...I think my car is terminal - pics inside chrisj Normally Aspirated Powertrain 9 06-29-2004 11:31 PM
NEED HELP...I think my car is terminal chrisj Service & Maintenance 1 06-29-2004 06:29 PM
NEED HELP..I think my car is terminal chrisj Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-29-2004 08:34 AM
