Old 01-10-2004, 04:58 PM   #1
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Default WRX heads/Cams with ej22 block
Ok I have a 99 L model with a NA ej22. Can I put the WRX heads and cams and turbo on this block and not have it explode at 20psi? I have read alot about the ej22t block and the ej25 heads/cams combo being very robust, do I have the same block in the ej22 as the ej22t? I ask because I don't have the money for the ej25, then the computer, the turbo etc. The wrx heads and cams on my block seems like a much cheaper and easier solution.
Thanks in advance from a newb!!
blaznc is offline   Reply With Quote
Old 01-10-2004, 06:49 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
20psi??? The stock WRX turbo cant do that much anyhow.
Old 01-10-2004, 06:53 PM   #3
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Unfortunately not, if you do a search, you'll see that the N/A ej22 is an open deck design, with cast internals, opposed to the forged internals (not pistons), and closed deck design of the ej22t. Hunt down a 91-94 legacy turbo sedan/wagon, and use that.
Here is WAC's very informative site...
Wedge is offline   Reply With Quote
Old 05-06-2004, 10:31 PM   #4
xtorted-legacy
Member#: 19568
1995 Impreza L
Brilliant Red
opppss....i am stupid. forget this post
xtorted-legacy is offline   Reply With Quote
Old 05-07-2004, 12:06 AM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Heres a thread with links to just about all the ej22 info on this board.
http://forums.nasioc.com/forums/show...highlight=ej22
FS: 05 wrx Heads, cams etc... no boost MAIC Private Classifieds 49 06-08-2009 03:32 PM
FS: NORCAL: 02 WRX HEADS/CAMS 53K Mi impreza.driver Engine/Power/Exhaust 5 08-13-2008 05:13 AM
2004 stock wrx td04, cams, 2.0 block Bombay994 Engine/Power/Exhaust 13 02-23-2008 11:53 AM
Using JDM heads/cams with US sensors/ECU, heres how... Invisiguard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 08-20-2006 01:19 PM
2.5RS with EJ22 block?! rdcalder Normally Aspirated Powertrain 12 04-09-2005 04:53 AM
