Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 01-10-2004, 05:58 PM   #1
b-o-b-s
Member#: 50148
2004 sti
jbp
Post odd swap
hey do you people have any info on a p1 2.5 with 2.2 heads and the thin head gaskets. thats what i am doing now but i was hopping you might know some specs.
b-o-b-s is offline   Reply With Quote
Old 01-10-2004, 05:59 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Whats a P1 2.5 ?
Wedge is offline   Reply With Quote
Old 01-10-2004, 06:23 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
phase 1
Why do you want the crappy 2.2 heads on there?
Old 01-10-2004, 08:07 PM   #4
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
I did that on my gocart engine. The CR is crazy. It would run like a diesel engine on starting fluid, no need for spark. It lasted for about 2 days of serious abuse and then it pounded the rod bearings to nothing. I had open exhaust and couldnt hear detonation. I just did the math and I came out with a 11.34:1 CR
Scoobie Steve is offline   Reply With Quote
Old 01-10-2004, 10:42 PM   #5
atabert
Member#: 45107
1992 Legacy L
Green
the stock cr on a 2.5l p1 is 9.5 :1, using the 2.2l heads will give you a smaller combustion volume which will increase compression, but not to 13:1, maybe 10-10.5:1, im doing the same thing, i used a 2.5l p2 sohc head gasket, and had to modify a little bit, but i works
atabert is offline   Reply With Quote
Old 01-11-2004, 01:57 PM   #6
b-o-b-s
Member#: 50148
2004 sti
jbp
Post
the main reason that i am doing this is because it is much cheaper then buying all new stuff. i am tradding my single ports for the dual ports, block and pistons are free. all i am buying are a few gaskets, seals, clutch, and some exhaust. this is fun for me and i like playing with this stuff. i know a guy that had this same setup and it lasted for a long time. the only reason he took it out is because he put dohc heads on his block.
oh yea my 1997 obs has 205,000 miles on it.
Old 01-11-2004, 07:15 PM   #7
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Compression
The 2.5 DOHC Phase 1 engine only has a 9.5:1 compression ratio in MY95 all the other DOHC 2.5 are 9.7:1
Joshua
yebokmj is online now   Reply With Quote
Old 01-19-2004, 08:38 PM   #8
b-o-b-s
Member#: 50148
2004 sti
jbp
Post
come on people, some one has to know a little bit about the power on this.
Old 01-31-2004, 04:08 PM   #9
b-o-b-s
Member#: 50148
2004 sti
jbp
sorry i told you i have a p1 2.5, but i have a p2 2.5. my bad. more comp more power!!!
VF swap done - odd noise at idle - Any ideas? cwepruk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-15-2006 07:32 PM
Odd Swaps ConstantProject Subaru Conversions 23 08-03-2006 03:40 PM
Odd engine swap question doghauler Off-Topic 4 03-24-2006 09:33 PM
odds/ends for rs-wrx swap? Parsons Subaru Conversions 23 08-26-2005 08:35 AM
Looking for some odd things and one non-odd thing scoobyimprza Mid Atlantic Impreza Club -- MAIC 2 09-26-2004 07:19 PM
