Welcome to the North American Subaru Impreza Owners Club Thursday April 24, 2014
Old 01-10-2004, 06:22 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Question ej20g injector problems
ok....so after one by one getting rid of ECU codes, i'm down to 14,15,16, and 17....error codes for the 4 fuel injectors. they're being grounded through the ecu this time. the injectors themselves are fine, the wire contiuity checks out. strange thing is though, when the ecu is powered up, i only register 1.63 volts going out of each injector wire. the manuals say i should see 10 - 13. any input? thanks.
smacksube is offline   Reply With Quote
Old 01-10-2004, 08:18 PM   #2
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
One terminal of the injector is connected to a switched 12v, I think its the yellow wire with red tracer, the other wire goes to the ecu and the ecu grounds it to fire the injector. With the ign ON you should see 12v at the injector terminal at the ecu. If you crank the engine the voltage will go from 12v to 0v very quickly. I would check to see if you have 12v at the injectors. If there is then would check for a bad ground.
Scoobie Steve is offline   Reply With Quote
Old 01-10-2004, 08:28 PM   #3
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
make sure that you have the right plug on the right injector (front to back) that would give you a code for all of them, i swapped them to see what it would do, and it idled fine but it gave me 14 through 17
bobturismo is offline   Reply With Quote
Old 01-13-2004, 01:50 PM   #4
Structure828
Member#: 50488
1999 GC8 ej20g!
Does ANYONE else have any input on this matter? If you do, please say.
Structure828 is offline   Reply With Quote
Old 01-13-2004, 03:12 PM   #5
bobturismo
Member#: 42145
6-4 jockin da bish-
check the resistence to ground on the computer and the vehicle, and then check the voltage going to the computer, if all that s good then the comp might be bad, you need more details, what did you mean "now its ground through the ecu" when wasn't it?,
does the car run?
my EJ20G injector flow results rob Pre-2002 Factory Turbo Powertrain 12 06-30-2012 02:25 AM
EJ20G injector o-rings and spacers rob Subaru Conversions 21 12-07-2006 10:43 PM
In need of EJ20G injectors Millencolin! Private 'Wanted' Classifieds 2 03-17-2006 01:35 PM
wtb ej20g injector silvialost Private 'Wanted' Classifieds 0 11-03-2005 03:00 PM
EJ20G Injectors NinNin Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-30-2002 03:37 PM
