Old 01-10-2004, 11:35 PM   #1
remz01
Member#: 32369
2004 wrx
java black
Default SSR Competitions. Need Advice.
simple question. 17s or 18s? and what is your reasoning?
*stock jbp 04 wrx
remz01 is offline   Reply With Quote
Old 01-10-2004, 11:43 PM   #2
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I went with 17's cause they're a little lighter and having a more protection with the 45's rather than the 40's 18's will have. 12.5lbs for the 17's and 15.5lbs for the 18's. I wanted to lower the weight from stock (16lbs) and the wheels look awesome too.
dj_noose is offline   Reply With Quote
Old 01-10-2004, 11:49 PM   #3
Dueysan
Member#: 50292
2004 Impreza WRX
Red
17's because popping tires and bending rims is an expensive and stupid habit.
Dueysan is offline   Reply With Quote
Old 01-10-2004, 11:51 PM   #4
remz01
Member#: 32369
2004 wrx
java black
any recommended tires?
Old 01-11-2004, 12:18 AM   #5
cnk
Member#: 10757
2013 BRZ Limited 6MT
17's here as well due to the bad roads here in NJ. I went with Falken Azenis ST-115 tires. . .very impressed with them.
Calvin
cnk is offline   Reply With Quote
Old 01-11-2004, 02:16 AM   #6
kenchan
Member#: 15106
17's cause i like the ride quality of 17's over 18's espcially with
S03's. also, unless you get larger brake rotors, you got a
huge-ass gap inside the wheel and it looks too rice to me.
if i go 18's it would be a mesh type wheel to cover up the
inside gap.
kenchan is offline   Reply With Quote
Old 01-11-2004, 02:00 PM   #7
Dueysan
Member#: 50292
2004 Impreza WRX
Red
Well on a 17" wheel your best match for overall diameter is going to be a 225/45R17 . I'm guessing your using the car in Florida so you won't have to worry too much about snow and ice, but perhaps lots of rain. I've been researching summer tires (for here in Montana) which would probably match your year round requirements pretty closely. I'm leaning towards the Bridgestone RE750, but there are plenty of other good choices. The Dunlop SP9000 is also on my list. If you want extreme handling with pretty crummy treadwear you might check out the Bridgestone S-03 tires or the Pirelli P-Zero Nero. If you want something with some more treadwear check out the Pirelli P-Zero Nero M+S......it's basically similiar to the Zero Nero but with a harder compound and some limited snow capabilities. You loose a little bit of maximum grip in exchange for better tread life and better temperature range. Unfortunately it is not available in the size I'm looking for 225/50R16 (incidently on a SSR competition rim), but I believe they make it in a 225/45R17. Good luck.
Old 01-11-2004, 06:59 PM   #8
makofoto
Member#: 25243
2006 Legacy Outback
A fellow I know has 18's (SSR's) ... broke one on a everyday bump that wouldn't hurt mine ... and I've had some nasty bumps ...
Lots of threads on "favorite tires"
What do you want from your tires?
toyo T1's!
makofoto is offline   Reply With Quote
Old 01-12-2004, 12:50 PM   #9
YinUCSD
Member#: 44945
05 Fxt
black
i agree 17" because of weight, a bit more rubber for protection and performance, price (remember 18" tires are more $ also). and 18s dont look so good if your car isnt lowered a little. stock wheel gap looks kinda weird with both 17 and 18 (especially).
as far as tires go, DUEYSAN basically summed up all the favorite tire threads. also check out the yokohama avs es100, very nice tire for less $. i have them now and they are GRIPPY! stiff sidewall even with my stock 16" size. very good in rain too.
YinUCSD is offline   Reply With Quote
Old 01-12-2004, 04:09 PM   #10
ElTorrente
Member#: 49964
2002 wrx
wrb
18" advantages/disadvantages:
Disadvantages:
Heavier
Rougher Ride
Lower Performance
More Road Noise
More Expensive
More prone to breaking/bending
Advantages:
Some people think they look cool
ElTorrente is offline   Reply With Quote
Old 01-12-2004, 06:05 PM   #11
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
18's are not neccessarily lower performance. For instance, all the rally teams run 18's on all the tarmac events nd they are some harsh roads. I know they have many rims, but rarely do you see ateam bending a rim from rough roads. If you spend the $$$$ a light, durable 18" wheel can be had.
essogas is offline   Reply With Quote
Old 01-12-2004, 09:09 PM   #12
Jon Bogert
Member#: 1133
'02 996 C4S '95 993
'71 911 3.0 '04 STI
Ok, so WRC quality 18" wheels will last up to 30-40 stage miles and another 50-100 transit miles before tires are dismounted and they're x-rayed for cracks. How does that give confidence to the street car owner with much lower grade wheels and no metallurgy facilties in his garage?
Jon Bogert is offline   Reply With Quote
Old 01-12-2004, 11:03 PM   #13
stiles_sm
Member#: 47828
'04 WRX wagon
... 03 996, 00 S4
Not meaning to hijack the thread, but what about 16x7 SSR comps? I'm considering these for my wagon...
11lbs, and some additional sidewall cushion...
stiles_sm is offline   Reply With Quote
Old 01-12-2004, 11:28 PM   #14
makofoto
Member#: 25243
2006 Legacy Outback
16" won't fit over Big Brakes ...
Some AutoX'ers like to use 16's because they are so light ... but GrassRootsMotor Sports test have shown that differences in weight barely make any difference in AutoX times ...
But 17's definitely firm things up and give better responsiveness, stability ... even Consumer Reports reported that ...
So I would think you gain more from the 17" then you gain from the weight savings of the 16's.
16's might be good for drag racing ...
Old 01-12-2004, 11:57 PM   #15
stiles_sm
Member#: 47828
'04 WRX wagon
... 03 996, 00 S4
Nice! Are those the 17x7.5 et50? Do they stick out of the wheel wells at all (in front, when the wheels are pointed straight.
I had heard the 16x7 ssr would fit over the 4-pots. What are you running?
Old 01-12-2004, 11:58 PM   #16
stiles_sm
Member#: 47828
'04 WRX wagon
... 03 996, 00 S4
Oh, and another reason I was thinking 16" in the SSR was the horror stories I used to hear about SSRs bending...
Old 01-13-2004, 12:03 AM   #17
Dueysan
Member#: 50292
2004 Impreza WRX
Red
Hey stiles..that's exactly what I'm going with ....16x7s SSR comps. That is the proper width for most 225/50R16 tires. A little wider than stock, slightly lower profile, almost identical overall size of the stock 205/55R16s....a good choice in my opinion. Check out the BBS RG-F's at the Tirerack website too.....available in 16x7 only, little expensive but very sweet. If I had a blue WRX sedan or wagon I'd go with a set of these in a heartbeat.
Old 01-13-2004, 12:23 AM   #18
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
Default Tires
I just got falken GR-B's, awesome grip wet and dry. I have yet to auto-x on them though. For the price ($95 for 225-45-17) they are tough to beat.
eyeballs is offline   Reply With Quote
Old 01-13-2004, 12:26 AM   #19
stiles_sm
Member#: 47828
'04 WRX wagon
... 03 996, 00 S4
The BBS RG-F is pretty, but the offset on the 16x7 ssr is better for the wagon (50 vs 48), plus they look tough to clean
Old 01-13-2004, 01:31 AM   #20
makofoto
Member#: 25243
2006 Legacy Outback
stiles ... can't find any shots with the front wheels straight ... but no ... they dont' stick out ... 17 X 7.5 50 mm
The tires however are only 215/45/17's ... going to 225/45/17's next time.
I've had some VERY hard run in's (head on) with my 17" SSR wheels/tires ... where I actually stopped to check my wheels ... I was sure they were bent ... but they've always been O.K. 16" is being too conservative ...
Old 01-13-2004, 06:49 PM   #21
SUBY2.5
Member#: 31985
06 Outback Wagon
I bent one of my ssr's hitting a pot hole crossing the gw bridge tire didn't go flat till about an hour later. But I got it fixed. But you feel everything on the road with an 18'' wheel. I feel the wheel bent to easily. Other than that a great looking wheel and light weight for a big wheel.
SUBY2.5 is offline   Reply With Quote
Old 01-13-2004, 09:39 PM   #22
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
Wow, looks sweet! Is your car lowered at all? I'm just wondering how a sent of 17 SSR-Type C's would look on a standard ride height car like my own.
Zuffy is offline   Reply With Quote
Old 01-14-2004, 02:13 AM   #23
makofoto
Member#: 25243
2006 Legacy Outback
Zuffy ... lowered on Tein Wagon Coil Overs ...
Here it is with oem springs ....
Old 01-14-2004, 02:27 AM   #24
Dueysan
Member#: 50292
2004 Impreza WRX
Red
Damn Makophoto your wagon looks really sharp.....now you've almost got me sold on the 17" wheels over the 16"s. I've got a red (real red not the maroon of earlier years) sedan and plan on buying the anthracite rims.......decisions decisions....
Old 01-14-2004, 02:34 AM   #25
makofoto
Member#: 25243
2006 Legacy Outback
I would have bought the anthracite SSR's if I had realized that they aren't too dark.
Anthracite SSR:
FS: NYC: SSR Competition Anthracite 18/with tires - needs repair - DIRT CHEAP!!!!!!!! DieselClown Tri-State Area Private Classifieds 13 01-03-2009 05:26 PM
SSR Competition - new old stock? Need one. jblaine Tire & Wheel 4 09-04-2008 08:05 AM
WTB: SSR stickers for SSR Competitions ommmjido Tire & Wheel 3 11-10-2004 03:15 AM
WTB: SSR stickers for SSR Competitions ommmjido Private 'Wanted' Classifieds 1 11-09-2004 08:08 AM
are these ssr type C's or ssr competitions? imprezive one Tire & Wheel 5 03-31-2004 04:38 AM
Message Board Statistics All times are GMT -4. The time now is 07:16 AM.
