Old 01-11-2004, 12:31 AM   #1
Lordhowe
Member#: 35265
Default OEM rim width
I did a few search but wasn't able to find what i'm looking for, my wording for the search might not be correct. Anyway, i was just wondering what's the width of our stock 16" rim? I thought they were 6", but i remember someone said they might be 6.5". Also, what's the rim width on a 2.5RS ( year 2001) stock rim?
thanks a bunch!
Lordhowe is offline   Reply With Quote
Old 01-11-2004, 01:19 AM   #2
bheinz57
Member#: 37870
2012 ISM WRX
'07 FXT Sports
16 x 6.5"
bheinz57 is offline   Reply With Quote
Old 01-11-2004, 05:49 AM   #3
ripvw
Member#: 27790
The 98 thru 2001 RS all had 16x7 wheels. They are a popular aftermarket upgrade for WRX owners. Used ones can be cheap, new ones run about $250 each.
http://www.subaruwrxparts.com/per-wrx-wheels.html
The WRX sold in other countries comes with 17x7 wheels, as well as 4-pot front brakes and 2-pot vented rears
Aren't we the lucky ones?
ripvw is offline   Reply With Quote
Old 01-11-2004, 03:57 PM   #4
Lordhowe
Member#: 35265
from my understanding that the 2.5RS have a differnet offsets than us, would that still be okay to fit on our car?
Old 01-11-2004, 04:01 PM   #5
Lordhowe
Member#: 35265
Another question, what's the biggest tire size that we can fit on our stock rims, and still maintain enough clearance from rubbing and not too much of the tire hanging over, that the beeds might have a chance of coming off from drifting. I was thinking about 225-50-16's or maybe 215 - 55 - 16 (but tires are very limited at this size).
Old 01-11-2004, 04:51 PM   #6
ripvw
Member#: 27790
The RS wheel offset is +53. Anything from +48 to +55 is usually thought to be acceptable.
Lots of people run 225/50x16 on the stock WRX wheels. They will perform and look better on the wider wheels, however. In addition, you get an additional .2" of contact patch width for every .5" of wheel width, which you might notice when cornering hard in the dry.
I wouldn't worry too much about the bead coming off the rim. Some people run 225/50x16 racing tires on the stock wheels without problems on the track.
What about 16x7.5 wheels like the SSR Competitons or the ASA LW5? Or 16x7 Rota Slipstreams? Both the SSR and Rota are lighter than the stock wheels and RS wheels. The ASA is an inch wider than the stock wheel yet weighs the same.
Another potential benefit: the RS wheels and the SSR's will allow you to upgrade to the Subaru 4-pot brakes. The stock wheels and the Slipstreams don't have the room. Not sure about the ASA's.
Rim Width issue, will a 9.5'' rim fit? enigma94 Tire & Wheel 10 10-29-2007 07:47 PM
Max optimal tread width to rim width chart? chimchimm5 Tire & Wheel 2 01-12-2007 11:27 PM
A question regarding max rim width for 18" rims for my 02 wrx wagon davejread Tire & Wheel 0 06-16-2004 04:29 PM
Tire width and rim width numbers? Any resources? ciper Brakes, Steering & Suspension 5 07-23-2002 10:43 PM
rim width, off set??? need help littleblue Brakes, Steering & Suspension 3 05-01-2001 12:31 AM
