Old 01-11-2004, 03:02 PM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default STI Active Suspension - Anything new ... ?
Anybody know more about the STI Active Suspension:
http://www.prodrive-usa.com/product_...d=10&pid=76&s=
makofoto is offline   Reply With Quote
Old 01-11-2004, 04:09 PM   #2
Chaste Automotive
Vendor
Member#: 44921
I will be at Prodrive on Tuesday I will get the scoop for you then, we return on the 17th and we have tons of new suspension options for all subarus.
Chaste Automotive is offline   Reply With Quote
Old 01-11-2004, 05:39 PM   #3
wgknestrick
Member#: 32576
04 STI
Those look very, very $$$$$$$$
wgknestrick is offline   Reply With Quote
Old 01-11-2004, 05:42 PM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the best information there seems to be about them is ~$3000 and they supposedly ROCK.
please update us, when you get some more details, Chaste.
nhluhr is offline   Reply With Quote
Old 01-11-2004, 05:52 PM   #5
makofoto
Member#: 25243
2006 Legacy Outback
Expensive ... but not that outragious considering their range ... if they work ... compared to other top of the line coil overs. Great for the well heeled weekend warrior ...
I guess these are the civilian version of what Solberg used in Corsica (Catalunya?) ...
Hopefully Caste Automotive will be able to give us some driving impressions ...
Old 01-12-2004, 02:21 AM   #6
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Hmmm seems like the same technology that GM is using for some cadillacs and 50th anniversary vettes. If it is as good, it is AWESOME.
mr2guru is offline   Reply With Quote
Old 01-12-2004, 03:27 PM   #7
Chaste Automotive
Vendor
Member#: 44921
Will do we will be getting all the information we are meeting with the engineers tomorrow so hopefully they will be able to shed some light on this. We have a lot of new products to offer since we have come across a few new manufacturers on this trip. We will release a carbon fiber prop shaft when we return.
Old 01-12-2004, 03:37 PM   #8
makofoto
Member#: 25243
2006 Legacy Outback
I hope you can give us some driving impressions with the Active suspension ... from slow and bumpy to FAST and hard cornering...
Old 01-12-2004, 04:53 PM   #9
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
That will fit the 6spd I hope
Old 01-12-2004, 05:06 PM   #10
jibco
Member#: 43598
06 WRX sedan
Default cool struts
I believe the vette dampers use an electric field to change the viscosity of the oil passing though unchanged piston orifices. the Prodrive units have a fast mechanical valve that changes the orifice size according to the info the computer gets from the two (wheel and body) accelerometers on each strut.
For $3000, that is mighty impressive suspension technology for the STi. It seems they should do well in the dailydriver/track/rallycross multirole stuff that alot of STi owners do.
I drove the 50th anniv. vette over the holiday, nice adjustable dampers. They are not "active" though, just 2 settings (sport and comfort). Not the same as this new prodrive setup.
Cheers,
Jeff
jibco is offline   Reply With Quote
Old 01-12-2004, 05:25 PM   #11
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
So how different is this from the Praxis stuff?
john
Old 01-12-2004, 05:38 PM   #12
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
john
The praxis is air and requires a compresser and tank, it also does not change damping by it self. The good side of the praxis is you can change ride hight and damping, from a track setting to a rally x setting. Thies will give you a better set up for the track but will not have the abilty to adjust for different conditions like the praxis will. Also I would be surprised if prodrive only charges $3k for thies.
Old 01-12-2004, 06:27 PM   #13
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Default Re: cool struts
Cheers,
Jeff
Hmmm I got my info from C&D article how the 50th vette changed dampening 1xx times a second through the magnetic sys.
Old 01-12-2004, 06:35 PM   #14
jibco
Member#: 43598
06 WRX sedan
I must be mistaken then. It may perform adjustments constantly under each of the "macro" settings with the settings purpose in mind.
Thanks for the info. It does make sense.
Old 01-12-2004, 06:58 PM   #15
Member#: 41166
2004 Impreza
Are there any specific questions that I can answer for you guys?
Basic information…
Target releases date – Early Summer
Target price – Less than $3000
Application – STi and WRX
Currently there are 2 vehicles in the United States running on this suspension.
After the first sets hit the market we will be looking into making the Active Shock Suspension for other vehicles.
This suspension was designed for the road version STi/WRX and is not the same suspension used in our Group N or Open Class Rally cars.
Kind Regards
Dan Antonielli
[email protected]
Dan@Prodrive-USA.com is offline   Reply With Quote
Old 01-12-2004, 07:14 PM   #16
typer_126
Member#: 14377
2004 STi
Twin Scroll Goodness
Cool
Hi Dan,
Just one question, where can I send my 3K to be vehicle number 3!
typer_126 is offline   Reply With Quote
Old 01-12-2004, 07:39 PM   #17
makofoto
Member#: 25243
2006 Legacy Outback
Will they work for the Wgn ...
Can one adjust the heights ...
Can they be biased one way or the other ...
Do you feel this is going to be the "perfect" solution for the "weekend warrior" who would like a bit of comfort driving to work ... but can hope to be decently competitive driving in AutoX (with the proper tires) on the weekend.
Old 01-12-2004, 08:15 PM   #18
Member#: 41166
2004 Impreza
makofoto...
The current prototypes are on STi’s… No wagons yet.
There are sensors in all 4 struts and a central unit.
The algorithm combined with the information receved from the sensors should be able to adjust to accommodate the wagons handling characteristics.
But I am not 100% sure due solely to the fact that it has not been tested on a wagon yet.
We are still debating the inclusion of height adjustment (coilovers)
The current prototypes are coilovers… so I think that is what we are settling on.
I will know for sure next month.
Our intentions in the future are to offer a dash module that will give the driver the ability to determine how the suspension reacts.
On paper this seems to be the ultimate solution but until I have a chance to experience this suspension myself I can’t give you an honest answer.
Regards
Dan Antonielli
[email protected]
Old 01-12-2004, 08:29 PM   #20
totoherbs
Member#: 7321
.... 122 IggPoints
If its under $3k I will realy have a hard time picking between it and the praxxis.
Old 01-13-2004, 01:30 AM   #21
crowbar
Member#: 14262
The key is to hit
really hard, with the bat
Originally posted by [email protected]
makofoto...
Regards
Dan Antonielli
[email protected]
danton,
i would gladly be prodrive's guiney pig for the wagon model.
crowbar is offline   Reply With Quote
Old 01-13-2004, 12:02 PM   #22
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
How much will these weigh compared to the stock struts?
Also, I put in a vote for making the coilovers!
Uber Wagon is offline   Reply With Quote
Old 01-13-2004, 02:55 PM   #23
Chaste Automotive
Vendor
Member#: 44921
Yes the carbon shaft is for both 6 and 5 speed versions. We have just been over to have a look and they are ready for production.
On the active suspension, we found out some of the details but I think that Dan can release the information since he has the test mules.
We saw the S10 WRC car getting a shake down for Monte Carlo and the new engine and trans package we will post pictures over the weekend.
Old 01-13-2004, 02:57 PM   #24
makofoto
Member#: 25243
2006 Legacy Outback
No driving impressions yet?
Old 01-13-2004, 04:46 PM   #25
thrdeye
Member#: 24569
2011 Impreza WRX
Hopefully this will be height adjustable.
It will be one of my last two prodrive products.
Going for seats, then the ACT.
thrdeye is offline   Reply With Quote
2005 STI Full Suspension, BRAND NEW! PENNYWISE330 Suspension/Brakes/Handling 11 08-06-2008 12:59 PM
Can someone tell me anything about the V2 STi RA suspension? Guru Imakuni Brakes, Steering & Suspension 5 11-28-2005 01:13 PM
Active Suspension for STi NYCshopper News & Rumors 14 11-06-2003 01:49 PM
From Autosport - Active suspension boost for Solberg cvalle-sd Motorsports 13 10-03-2003 12:15 PM
ACTIVE suspension for weekend worriors Donaldson395 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-27-2001 10:50 AM
