Old 05-21-2000, 10:56 PM   #1
ImprezaRS2000
Member#: 779
1998 STi Wagon
Question An oil question...
I recently changed my oil (at the 6k mark). I am using Valvoline DuraBlend 10W-30, since it's summer. Anyways, when I checked the previous oil level, it was low! Does the RS burn oil or something? It wasn't leaking; I checked for that. So I was thinking of putting 5 quarts in instead of 4.2. I didn't, though, because it could be really bad, so I thought I'd ask you guys (and gals) for advice for the next oil change.
ImprezaRS2000 is offline
Old 05-21-2000, 10:59 PM   #2
Pilot
Member#: 513
Post
Don't over fill the car with oil. You can get a whole host of problems (oil cavitation causing starvation of the oil pump, blow by at the rings seal problmes), just check the level often and add as needed.
All cars burn oil.
Pilot is offline
Old 05-22-2000, 09:50 AM   #3
ImprezaRS2000
Member#: 779
1998 STi Wagon
Post
Thanks!
HTML code is On
Three questions. One about an oil pan, one about fuel, and one about intake manifold Cyclops Built Motor Discussion 19 12-25-2008 05:30 PM
An oil question... jamapor Mid Atlantic Impreza Club -- MAIC 31 08-22-2007 11:01 AM
Quick Question about fitting an Oil Temp. Sensor nxwrxfx Factory 2.0L Turbo Powertrain 1 05-11-2006 12:41 PM
Question about getting an oil cooler SubyNewbie Mid Atlantic Impreza Club -- MAIC 5 10-04-2002 01:00 PM
How many quarts of oil for an oil change? codemunky Service & Maintenance 9 07-30-2002 06:35 PM
Message Board Statistics All times are GMT -4. The time now is 11:03 PM.
