Old 01-12-2004, 12:29 AM   #1
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Default I got nailed!
Well the other day I started hearing a new noise from my car, it turns out i have a nail in my back drivers side tire. What should I do? I have stock rims/tires with about 19k on them, i almost need new tires but not really. I need some opinions. Thanks.
--Ryan
m u f a s i s is offline   Reply With Quote
Old 01-12-2004, 01:59 AM   #2
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
Replace the tire or get it plugged (preferably from the inside out).
02R6 is offline   Reply With Quote
Old 01-12-2004, 04:29 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I am an "expert" at plugging tires since I used to get a lot of nails and screws where I used to live. I never had a plug leak on me and I didn't ever take it easy on the tires after they had been plugged.
nhluhr is offline   Reply With Quote
Old 01-12-2004, 12:42 PM   #4
YinUCSD
Member#: 44945
06 LGT wag
jsut get it plugged / patched. discount tire does it for cheap and guarantees their work. i wouldnt buy a new tire, let alone another re-92. if you decide to replace a tire you can do one of two things:
1. buy two tires and put both on either front or rear (this is expensive, might as well wait to get all 4 new tires, and not re-92's).
2. buy one tire, get the tread worn down to match the other 3 (although this is a waste because you are buying a whole new tire to match 19k mile used tires, when you havent even used the new tire for 19k.)
so, plugging it is the best option since your tires are already 19k used.
YinUCSD is offline   Reply With Quote
Old 01-12-2004, 01:24 PM   #5
Tire Rack Moderator
Member#: 1215
ext. 4362
get it patched
Old 01-12-2004, 01:47 PM   #6
IntraWRX
Member#: 20773
Midnight Black Pearl
is patching/plugging the same thing?
IntraWRX is offline   Reply With Quote
Old 01-12-2004, 03:06 PM   #7
YinUCSD
Member#: 44945
06 LGT wag
i think so, at least i use them synonymously when talking about car tires. luke would know, he knows all.
Old 01-12-2004, 08:16 PM   #8
BlkTS02
Member#: 50142
2002 2.5TS
MBP
no, they're not the same.
Plugging is just what it sounds like. Plugging up the hole where the nail is. The problem is when the tires heat up from either driving or the weather the adhesive can soften and the plug can fail, which is why most tire shops do not plug tires.
Patching involves pulling the tire off of the rim and applying a patch to the hole from the inside. The advantage is that both the tire pressure and centripedal acceleration of a rotating wheel will act to hold the patch in place.
I've seen prices ranging from $6 to $15 for patching, it just depends on where you go.
Dave
BlkTS02 is offline   Reply With Quote
Old 01-12-2004, 10:26 PM   #9
Porter
Member#: 486
2004 Forester XT
bug spattered
I prefer a patchplug. Best of both worlds.
Porter is offline   Reply With Quote
Old 01-12-2004, 11:57 PM   #10
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
Patch and plug... unless it is within 1 inch of the side of the tire or touches the sidewall in any way.
KoneKiller is offline   Reply With Quote
Got nailed by the storm? Now get nailed by your insurer. Porter Political Playground 30 09-12-2005 01:31 PM
Was alongside an Audi S4 and we both got nailed for "racing" and speeding kcollins Mid West Subaru Owners Club Forum -- MWSOC 4 10-25-2002 12:14 AM
HELP!! This out of towner just got nailed (need a body shop) t-bone Southern California Impreza Club Forum -- SCIC 2 08-26-2002 11:42 AM
I got nailed! BADWRX Bay Area Impreza Club Forum -- BAIC 19 07-09-2002 11:59 PM
I got nailed on Rt 1... WRXTeamDFL Tri-State Area Forum 7 06-07-2001 07:14 AM
