#76 | |
Member#: 94945
Vehicle:1995 Legacy OB 5MT 2003 Forester X 5MT |
![]() That still seems awfully light, so I guess they did make 2WD in 96.
#77 | |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
, I have been asking for some for like going on a year now with no luck, I have not seen one pic, not even a build pic!!come on brent you are killing us, its good to see you are still around though. Ben |
#78 | |
Member#: 13617
sorry, just had to comment on that part ![]() Ben |
#79 | |
Member#: 66304
Vehicle:98 RWD BG Outback ...with R200 and ITBs ;) |
#80 | |
Member#: 66331
Garrett t3/t4 turbo Custom Invidia Downpipe 3" catless TBE Turbosmart external wastegate @ 18psi wastegate external dump (extremely loud) cops love it Spearco FMIC 550 cc Injectors walbro fuel pump Stage 1 cam regrind MSD ignition Iridium plugs 1 stage cooler Later model Intake manifold K&N cone filter Apex'i S-afc II Apex'i SITC 4.11 manual transmission (2.5RS) exedy clutch sti short throw shifter Fidanza Flywheel port and polished throttle body no knock sensor no a/c no power steering no abs no fuel cut no front bumper beam airbag system pretty much removed no speed govenor and I've pegged the gauge at 140mph many times, not in the 1/4 mile, but 5th gear pulls as hard as 3rd and 4th. There is a video i put on the net somewhere of it pulling from 20-60 in second gear. Before I worked out the fuel ratio's and Ignition timing. It's pretty crappy quality though. I wish i could have gotten a video of the cobra i was playing with on the interstate. It was pulling me but not by a lot. The car is kinda a PITA though and i'm getting sick of constantly fixing stuff. Right now the O2 sensor isn't working and the valve guide on the wastegate is warped so it likes to stick open. Last edited by DamienX; 10-09-2005 at 03:01 AM. |
#81 | |
Member#: 13617
Ben |
#82 | |
Member#: 60224
Vehicle:2008 FXT Sports 2.5 Dark Grey Metallic |
![]() Man that sounds like one hell of a system. What year Legacy is this and what short-block are you running? You must be really light to get it down into the 12’s. As for me, my Legacy’s got a big ass and is still very heavy, or at least more so than a wrx so it’s hard to carry over comparable 1/4 mile times. My best so far is: R/T: .065 60’: 1.93 1/4: 13.7 MPH: 98.8 That’s at 5,500 RPM launches and flat-foot shifting. The 60’ could be lower but I think the weight is holding it back at about 3,165lbs. As for the SVT Cobra’s, I too had the opportunity to run three rolling starts (40-100mph) against a 99’-04’ model (in a closed course environment ). The first two runs I pulled a half car length before shutting down at 100mph and the third run was the reverse. The driver and passenger were shocked with each pull and probably went home and bought some more bolt-on’s after getting walked twice by a family sedan… ![]() |
#83 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
xcntrk - I'm guessing that that Cobra was a 99 or an 01. The '03s and '04s run high 12s out of the factory and 11s with Intake/Pulley/exhaust. Either way, still a nice eye-opener for the driver of the 'stang
#84 |
Member#: 60224
^^^ Must have been, I only spoke with the driver briefly and didn’t get the year or spec’s. It was the 99-04’ body style was my point.
#85 |
Member#: 66331
I have an EJ22T block in a 93 legacy SS. The 03 and 04 mustang cobras are pretty quick. I think they make somewhere around 390 hp. That's not too bad of a 60', but your probably right about the weight killing you. If you get ambitious, you might scrape up some of the sound deadening material.
#86 |
Member#: 22879
Loosing weight on a legacy is easy, or at least it was for me. They are really not that much bigger than the earlier GC imprezas which can be realllllly light. I choose to leave in the sound deading material as i hate noise. Lost just about everything else though.
I do however have a sunroof, power windows and locks. Those are the reason i buillt this car and something i didn't really want to live without. I know a guy that has a newer cobra with the basic mods making around 500 whp. Maybe i'll get ahold of him and see how mine stacks up. B |
#87 |
Member#: 13617
do we get any pics though?
Ben |
#88 |
Member#: 4736
SCIC
Vehicle:95 12 sec. Legacy Same Color as a Booger |
Until we get pictures I call
MV |
#89 |
Member#: 66331
Yeh, i still have my sound deadening material and power everything. Not something i wanted to live without. A lot of the stuff that holds the car together is temporary which is probably a big reason as to why im always fixing stuff. baling wire keeps the wastegate from hitting against the plug in the firewall where the a/c went. A n/a radiator replaced the turbo one when the coolant sensor went bad and the turbo radiator split. I also had involuntary weight reduction when my car was broken into and the original stereo system got stolen.
One of these day's i'll get around to fixing everything up nice. But right now i go to school full time and work full time so i'm fairly busy. Sry bout the crappy pics, the cam is an ebay special and i never figured out the date thing on it. It's funny how people call bs. ![]() Looks pretty stock on the outside doesn't it. Last edited by DamienX; 10-10-2005 at 02:15 PM. |
#90 |
Member#: 60224
You called the BS bluff...!Looks sweet main... I especially like the external WG, which vented to the atmosphere must be super LOUD! So why did you position the O2 so close to the turbo, are you pulling WB data? |
#91 | |
Member#: 4736
SCIC
MV |
#92 |
Member#: 66331
There's actually two places for an o2 sensor, one is at the base of the downpipe and the other one you can see. It runs better where the exhaust is hotter. The O2 sensor tells the computer whether or not to add fuel based on temp. So if the exhaust cools down too much, it thinks there is too much fuel and not enough air, and if its hot, it reads too lean and adds fuel, I don't think it really matters with the s-afc unit tuning the fuel as long as the readings are consistent. I figured it was better closer to where the reading matters. 3" stainless steel lets the exhaust cool pretty quickly.
I think the best mod is the piece of electrical tape i usually keep over the turbo badge on the back. It catches a lot of people unaware. |
#93 | |
Member#: 4736
SCIC
MV |
#94 |
Member#: 66331
LoL. I thought you were calling BS on my 12 sec legacy. Here i took the time to go out and take pics and then resize them no less..
#95 | |
Member#: 13617
Ben |
#96 |
Member#: 22879
Who said i was planning on providing pics?! I kinda like keeping people on the edge and wondering....
#97 | |
Member#: 76382
BAIC
Vehicle:2000 BH BP Wannabe |
#98 | |
Member#: 13617
![]() Ben |
#99 |
Member#: 22879
Technically not everything is done. I STill haven't put all the interior back in.
B |
#100 | |
Member#: 4736
SCIC
MV |
| Thread Tools | |
| Display Modes | |
| Jesus is truely among us | incorporeal | Off-Topic | 77 | 02-01-2006 06:20 PM |
| There's a spy among us! LMAO ROFLISM!! | chris619 | Off-Topic | 12 | 04-26-2004 12:18 AM |
| northeastern is among us.. | capaWRX | General Community | 22 | 12-07-2003 12:15 AM |
| Ghosts Among Us | maclif | Texas Impreza Club Forum -- TXIC | 1 | 08-30-2003 03:49 PM |
| Is there a trader among us? | 2DEDGE | New England Impreza Club Forum -- NESIC | 1 | 11-28-2001 09:35 PM |
