Tire & Wheel Forum sponsored by The Tire Rack |
01-12-2004, 10:32 PM | #1 |
Member#: 38084
Vehicle:2003 Forester 2.5 XS Platinum Silver |
Ground Clearance
I have a 2003 Forester which currently has the stock wheels and tires (215/60R16) on it. I'm buying a set of stock '02 WRX wheels from someone and want to mount Dunlop Winter Sport M3's (205/55VR16) on them and use these wheels for winter driving. Is the difference in sidewall height going to make much of a difference in my vehicles ground clearance. As I understand it, it should only be about 17mm shorter which doesn't sound like much to me but I'm no expert by any means. Any help/info on this would be much appreciated.
Tim
01-13-2004, 09:58 PM | #2 |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
215 x .60 = 129 mm
205 x .55 = 113 mm 129 - 113 = 16 mm = 2/3 in = no big deal for a Forester |
01-13-2004, 10:59 PM | #3 |
Member#: 48928
Vehicle:'02 WRB WRX Sedan '11 DGM WRX 5dr Premium |
Your speedo will be too fast by 4.9% though.
When traveling 60, you will only be doing 57.1 MPH. |
01-14-2004, 01:37 PM | #4 |
Member#: 30342
You shouldn't have clearance problems. The concerns would be speedo (I thought the Forester was geared too low already ), and load rating.
I'm not sure how much heavier the Forester is than the WRX, but the undersized tires will have a lower load rating. I'm not sure what tires the Forester comes with, but 215/60 RE92s have a load rating of 94, or 1477 lbs. The 205/55 is 89, or 1279 lbs. The M3 is stronger, at 91, or 1356 lbs, but you are still losing 100 lbs load capacity at each tire. |
01-15-2004, 01:01 AM | #5 |
Member#: 38084
The Forester came with Yokahama Geolandar 215/60R16's. Not sure what load capacity was but I don't plan on packing her full of lead weights any time soon so I should be okay on that end of it. As for the speedo aspect, is that a big deal? I should just drive a little slower than my usual 10mph over, right? 4.9% doesn't sound too bad to me but I'm no expert. Thanks for the info.
Tim |
01-15-2004, 09:29 AM | #6 |
Member#: 30342
According to Tirerack, the Geolanders carry a 94 rating. And I'd agree, the 100lbs shouldn't be a problem.
But since your speedo reads fast, you'll have to go faster than you normally would to maintain the same speed. (When speedo reads 60, you're actually doing 57.1). Also, your odometer will register 5% more miles than you actually travel. |
Turbo-back ground clearance | snowrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 01-25-2002 12:18 AM |
high ground clearance my a$$... | janikphoto | Normally Aspirated Powertrain | 11 | 12-24-2001 01:00 PM |
('93-'01) Winter is coming and I need advice on my ground clearance | Ripper | Impreza Forum | 12 | 10-29-2001 05:34 AM |
Sway bar and ground clearance | DEVO-2nd GEN | Brakes, Steering & Suspension | 6 | 08-31-2001 02:55 AM |
Ground clearance with P1 lip and P1 suspension? | Arch | Interior & Exterior Modification | 6 | 04-21-2001 01:31 AM |
