Old 01-13-2004, 12:35 PM   #1
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Question WRX ECU ignition map conversion factors
In the stock ECU (viewed via EcuTek Flash2002 or similar viewer), the ignition map values in both the main ignition and ignition correction maps are one byte values...
Does anyone know the conversion factor for these (ie, 0x00 = 0 degrees BTDC, 0xFF = n degrees BTDC) for either or both of these maps?
Is it a linear or nonlinear relationship (I'd certainly hope it's linear...)
My research is showing 0xFF on the ignition correction map would be 90 degrees, and 0xFF on the main ignition map is 31.5 degrees.
What are you guys seeing?
Thanks,
/Andrew
Kha0S is offline   Reply With Quote
WRX to WRX ECU conversion hernan Engine Management & Tuning 1 04-19-2004 06:20 PM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 04:19 AM
Bar to PSI conversion factor? makofoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-09-2003 02:14 PM
Definitive Post on ECU re-building Fuel/Ignition Maps is2scooby Engine Management & Tuning 8 11-07-2002 06:54 PM
Conversion factors dealing with boost 98mpreziveRS Normally Aspirated Powertrain 8 02-02-2001 01:45 AM
