Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 01-13-2004, 01:57 PM   #1
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Default AVCS advance
What do you guys with AVCS heads see for advance normally? I know it depends on that ECU you are using. I'm using an AH581 ECU with V8 RA heads, at low TPS and MAP I see 40 degrees of advance, that's as high as it goes. It then trails down to around 25 or lower at higher RPM. I haven't really pushed the car so it's not seeing more than 10psi of boost right now and hasn't seen above 6000 or so for RPM.
Maximum AVCS Advance w/ Cosworth cams? wittmer25 Built Motor Discussion 44 02-08-2010 10:12 AM
Too much AVCS advance? Infamous1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-08-2008 10:39 AM
Maximum AVCS Advance w/ Cosworth cams? wittmer25 Open Source Reflashes 3 01-17-2008 10:34 PM
AVCS advance clarification drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 04-13-2006 04:50 PM
AG970 STi RA ECU and AVCS Advance... 30 degrees? dug-e-fresh Engine Management & Tuning 0 11-04-2003 03:10 PM
