Old 01-13-2004, 10:51 PM   #1
rsr911
Member#: 3813
2002 AMG CLK55
Default Help wheels dont clear my DMS coilovers!!!
HELP!!!
I just purchased a set of ROTA tarmac 1s
17 x 7.5 48 mm offset. They clear the Wilwood big brake kit fine. Lots of room up front. They dont clear the the springs on the rear struts.
I need to find a wheel and tire combination that fit any suggestions?
Owen
rsr911 is offline   Reply With Quote
Old 01-13-2004, 11:53 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Can you use different camber washers in the rear so you have more clearance?
Old 01-14-2004, 10:07 AM   #3
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
which DMS are you running.
sd
suby_dude is offline   Reply With Quote
Old 01-14-2004, 11:32 AM   #4
rsr911
Member#: 3813
2002 AMG CLK55
I am running DMS 40 mm.
I do have a rather aggresive alignment both front and rear. I am looking into what my settings are and seeing if adjusting the rear alignment will give me enough clearance. My Speedline GT-1s just clear and I did have a rubbing issue with them when I first installed the struts as well.
Owen
Old 01-14-2004, 01:47 PM   #5
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
Would a narrower tire help?
Or maybe a 5mm wheel spacer and longer studs?
I dunno if Rota offers a +40 offset which would push your wheels out a bit to get them away from the springs.
I'm glad that you posted this, I was considering a DMS kit, but didn't know if there would be fitment problems with different wheels.
I know that when SCC tested the DMS 40mm kit in 8/2003, they used an Enkei 17x7.5 wheel with a +48 offset and had no rubbing problems. Don't know what size tire they used though.
mbeach is offline   Reply With Quote
Old 05-26-2005, 01:55 PM   #6
rsr911
Member#: 3813
2002 AMG CLK55
Angry Here we go again!!!
Just got 2004 STi rims and tires and of cource they dont fit either.
Any suggestions. I have gotten some suggestions....wheel spacers, camber plates, etc. Suggestions for alignments would be helpful as well. I hear the the RE-070 do not like lots of negative camber?
Owen
Old 05-26-2005, 03:10 PM   #7
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
If you're running long springs or too low ride height, the wheel/tires can rub on the lower spring perch or the spring itself. Are your springs too long so that when you raise the lower spring perch above the tread of the tire, you're ride height is too high? If so, it sounds like shorter springs would solve the problem.
Think about it as a whole system. There's never going to be enough room for a beefy strut + another 1/2 - 3/4" for the adjusting collar next to your tire unless the tire is narrow, or your wheel has less offset.
Jon Bogert is offline   Reply With Quote
Old 05-27-2005, 01:25 AM   #8
rota wheels wrx
Member#: 13856
04/5 STI
white/WRB
If it is rubbing in the struts, one fix I can think of is running lower offset wheels. No matter what design you use, if it is rubbing on the strut, you will have to go lower in offset.
Of course a skinnier or lower profile tire might work also
rota wheels wrx is offline   Reply With Quote
Would 02 WRX DMS coilovers fit my 00RS GC8? Rallly2000 Brakes, Steering & Suspension 28 11-26-2009 03:27 PM
HELP! cobb block pistons dont clear valves! IllNastyImpreza Built Motor Discussion 57 03-08-2007 08:02 PM
wheel Offset for DMS coilovers? Chris N Tire & Wheel 1 12-09-2006 10:52 PM
bored at work. i dont wash my wheels. d100 aaronSTi Member's Car Gallery 36 09-15-2006 04:20 PM
Does anybody have Tein/Leda/Cusco/DMS coilovers in Atlanta? DanMan South East Region Forum 8 10-02-2001 10:13 AM
