Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 01-13-2004, 11:16 PM   #1
bruticus
Member#: 10640
look like a bitch?
Say what again!!
Default My car probably won't start in the morning due to cold. Any suggestions?
I don't know the best place for this, but since the TriState area is currently experiencing a deep-freeze I'm hoping somebody can offer help.
As referenced here, Friday night/Saturday morning my car refused to start due, I believe, to the extreme cold. It finally started Saturday after warming up a bit.
This evening when I got in to leave my sister's house (the car had sat from ~5:30-10:30) it took 2 minutes of cranking before it'd start. The overnight temps are expected to hit 10F and not go up much at all Wednesday so I'm assuming that, in the morning, it will not want to start.
The car sits ~150 feet from my door/nearest power outlet, and there's nowhere warm I can put it anywhere around here. Is there somewhere I can pour hot/boiling water to attempt to thaw a frozen fuel line?
Please help; I can't afford to be out of the office for a day.
TIA
DjB
bruticus is offline   Reply With Quote
Old 01-14-2004, 01:22 AM   #2
Kitsune
Member#: 28934
95 Miata
89' BMW 325is
Best suggestion I can offer is to take the car for an hour drive to give the battery a good charge if your that concerned. I have'nt had any problems with my car's battery, so, I'm not really sure what the deal is with all these newer models blinken out.
Kitsune is offline   Reply With Quote
Old 01-14-2004, 02:50 AM   #3
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Doesn't sound like the battery, since he cranked it for a while to get it started. Go get some fuel-line dry-gas and fill up the tank. it will absorb the moisture in the tank/fuel.
-mike
Paisan is offline   Reply With Quote
Old 01-14-2004, 09:16 AM   #4
Rich10
Member#: 14934
One thing that helps my WRX on very cold mornings is to turn the key to the auxiliary position first and leave it there for a couple of seconds. I believe that allows the fuel pump to build a bit of pressure. It helps my car to start on cold mornings.
Rich10 is offline   Reply With Quote
Old 01-14-2004, 11:01 AM   #5
WRX 2NV
Member#: 32884
Fast & Furious -
Erik's Furious, I'm Fast
Agree with the 2 guys above. Get a good charge so you can crank for a bit, put in some dry gas and maybe look into one of those electric motor blankets that warm up your engine compartment.
WRX 2NV is offline   Reply With Quote
Old 01-14-2004, 12:05 PM   #6
elsanto
Member#: 34832
1989 M3
another tip from us winter sports advocates.. if it IS your battery you can easily remove it for the night store it inside and throw it in first thing in the morning.. not sure about frozen fuel lines tho...
elsanto is offline   Reply With Quote
Old 01-14-2004, 12:19 PM   #7
aidrock
Member#: 21028
2002 WRX Sedan WRB
02 Triumph Sprint RS
Rich10 is right, turn the key to the on position and leave there until you hear what i believe is the pump turn off (usually 2 or 3 seconds thereabouts). your car should start right up unless there is something going with your battery, but if your car is turning over then it isnt your battery.
~aidan
aidrock is offline   Reply With Quote
Old 01-14-2004, 12:46 PM   #8
bruticus
Member#: 10640
look like a bitch?
Say what again!!
As paisan said, the battery has plenty of juice to spin the starter. I put in a bottle of dry-gas Saturday after finally getting it started (I filled the tank Thursday night and it was only 1/8 down since I hadn't driven it Friday night-Saturday) and another bottle last night after its hard start.
I've listened for the fuel pump noise but can't hear it; either my hearing isn't sharp enough (I have lost some hearing acuity due to unknown causes) or it's just particularly quiet.
DjB
Old 01-14-2004, 01:08 PM   #9
aidrock
Member#: 21028
2002 WRX Sedan WRB
i have found that the fuel pump usually runs from the time you turn your key to on until about the time you would hear your radio play if you have it on. that is another way to time it if you cant hear the pump itself running
PROBLEM!! crank case sensor, wont start in the morning sike43 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-09-2010 07:32 PM
I don't think my house will be here in the morning. Vostok 7 Off-Topic 40 10-25-2009 01:13 PM
**help needed, cars battery seems weak in the morning. ultraspdWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-02-2006 08:12 PM
UTEC in Australia!!! - knocking due to cold air rstlss UTEC 28 03-29-2006 01:50 PM
My car probably won't start in the morning due to cold. What should I do? bruticus Service & Maintenance 22 01-15-2004 12:15 PM
