Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 01-14-2004, 09:36 AM   #1
hatake
Member#: 34811
04 Baja T
Default Grill Mesh - DIY
Let's see if the link works...
http://images.cardomain.com/member_i...261_4_full.jpg
Gutter Guard at Home Depot, just right size for under 5 bucks. Split into 2 (hood latch space), snip around, make sure surface is as smooth as possible, then bolt them down with small screws and nuts. I used hex screw with round head for invisibility. Works fine to fend off small rocks CDOT uses when it snows.
http://images.cardomain.com/member_i...261_5_full.jpg
From the inside.
hatake is offline   Reply With Quote
Old 01-14-2004, 11:35 AM   #2
SouthShoreBaja
Member#: 50658
2006 2.5RS
Hey hatake, looks great!
What's the makeup of gutter guard, stainless steel etc?
SouthShoreBaja is offline   Reply With Quote
Old 01-14-2004, 12:15 PM   #3
hatake
Member#: 34811
04 Baja T
Humm, I didn't pay attention to it... Something that doesn't rust, obviously from its original intended use (gutter), I assume. The mesh itself is a cut-type (as opposed to braided) that edges are a bit rough. But I really don't care how it looks as long as it blocks small rocks. My Impreza radiator was filled with rocks/bugs/garbage after 4 years, and that just got me concerened with turbo. Also there is this store called Container Store that sells tall/large garbage can with finer mesh. Take that appart and you can make a better (painted - I saw pink!) mesh. I also got a roll of, again, different gutter guard (this one is a thin wire-braided AL mesh, lots whimpier than one used in grill, but wires are so thin, they wouldn't block the air) at less than $5 and made an IC screen. It just rests on the IC core. I used to have an AL window screen inserted between IC rubber duct and hood, but window screen had too much wind resistence.
Next project - DIY turbo heat escape, or resonator removal (but I have to take a sick day to do this while the Wife is at work - she has a tendency to take a sick day when I take one ).
Where to get sti grille or 04 impreza type grill mesh? pleue Interior & Exterior Modification 7 08-09-2005 11:07 AM
Looking for grill mesh like STi mesh pdippel Interior & Exterior Modification 2 02-27-2004 12:14 AM
DIY grill mesh thisisbrock Interior & Exterior Modification 16 02-18-2004 04:52 PM
Front grill mesh mod, the grill with the badge... wcbjr Interior & Exterior Modification 7 04-06-2001 11:13 AM
front grill mesh cover Robmat Technical Forum Archive 6 09-21-2000 09:15 PM
