Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 01-15-2004, 12:26 AM   #1
Baja Turbo
Member#: 49744
2004 Baja Turbo 10
Regetta Red Pearl
Default Cruise Control
If your cruise control is slow to set(non turbo)Try taking up the slack in the cable.My 03 was that way ,you would have to hold the set position until you felt it come on.Check the slack on both cables.Makes a big difference.
Baja Turbo is offline   Reply With Quote
Old 01-16-2004, 10:41 AM   #2
hatake
Member#: 34811
04 Baja T
Humm, my cruise control comes on with a pause, but nothing different from what I've driven/owned. Are you having the same issue with turbo? Turbo models come with fly-by-wire throttle - how does that affect this issue?
hatake is offline   Reply With Quote
Old 01-17-2004, 08:56 PM   #3
Baja Turbo
Member#: 49744
2004 Baja Turbo 10
Regetta Red Pearl
No problems with the fly by wire,actually its fast.My 03 Baja was slow to respond and by taking up the slack took care of the problem.
easiest way disconnecting cruise control cable from TB, cruise control removal 02-03 fastwrx25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2008 08:30 PM
UTEC: If the cruise light is flashing....cruise control doesn't work? bpwatts Engine Management & Tuning 4 07-10-2006 08:07 PM
Cruise Control Aint Cruising ahawks Service & Maintenance 0 10-21-2005 02:12 PM
Cruise actuator but no cruise control!! Improviser Normally Aspirated Powertrain 14 11-13-2002 05:48 PM
