Old 01-15-2004, 01:09 AM   #1
ImprezedRS
Member#: 2771
2003 BMW Z4
Default Will this tire fit?
Ok I have been looking at tires latly and a lot of different sizes. Ok the final size I believe I'm goign to go with is a 255/35R18. But my problem is that it says that the won't fit less than a 8.5" rim, but on my rims now I have a 245/45R18 and yet it looks that I could squeze the 255s on. My rims are 8 inches wide. Also at my work we have the tire mounter with the helper arm on it, so I should be able to get these on.
ImprezedRS is offline   Reply With Quote
Old 01-15-2004, 07:00 AM   #2
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
If you're talking about the rotas you showed in the other thread, they are 7.5" wide, not 8. I have seen an accident caused because a guy was driving hard with tires that were too wide for his wheels. One of the tires literally popped off. I would stick with the tire manufacturers recommendations.
rex n effect is offline   Reply With Quote
Old 01-15-2004, 07:04 AM   #3
rex n effect
Member#: 15289
02 wrx pollen silv
I have a feeling that the second you drive hard at all on those tires, they will rub all over the place. If you get them to work, then more power to you!
Old 01-15-2004, 08:06 AM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Even if you get them on, the sidewalls and shoulders will be rounded. This will reduce the contact patch, negating any advantage of the wider tire. You'll have the same contact patch, but just more weight. I wouldn't do it.
Also, what vehicle are these going on? I assume you at least have the fenders rolled, or maybe even a wide body kit?
Old 01-15-2004, 11:19 AM   #5
ImprezedRS
Member#: 2771
2003 BMW Z4
they going on the subaru
Old 01-15-2004, 11:25 AM   #6
mav1c
Hoodbridge!
Member#: 560
An Impreza 2.5 RS? WRX?Wagon? Legacy? Outback? Forester?
Old 01-15-2004, 09:50 PM   #7
ImprezedRS
Member#: 2771
2003 BMW Z4
A 2000 Impreza 2.5RS
Old 01-15-2004, 10:27 PM   #8
mav1c
Hoodbridge!
Member#: 560
Do you have a widebody kit? Because there's no WAY that size tire would fit otherwise.
Old 01-18-2004, 02:05 AM   #9
ImprezedRS
Member#: 2771
2003 BMW Z4
no widebody kit, it will fit with some modifications of some things.
I have already currently mounted a 245/55 18 on my 18s and will fit in the wheel well being 3 ins from stock height. I will need to raise it up a inch though.
Old 01-18-2004, 09:11 AM   #10
mav1c
Hoodbridge!
Member#: 560
So you are raising the car to fit HUGE wheels and tires. I am assumming they "stick out" past the fender?
Question...why?
I'd like to see some pics of 245/55/18's on an RS.
Old 01-18-2004, 11:20 PM   #11
ImprezedRS
Member#: 2771
2003 BMW Z4
Heres your pic
Old 01-19-2004, 07:29 AM   #12
mav1c
Hoodbridge!
Member#: 560
And those don't rub?
Old 01-19-2004, 07:19 PM   #13
ImprezedRS
Member#: 2771
2003 BMW Z4
If I turn the wheel it will rub, thats the reason for the 1 inch raising the car. I need to raise it anyways.
Will these tires fit on my 04 wrx stock wheel? Michelin 17/65-15 Rally tires. Landsharkk Tire & Wheel 4 10-12-2008 02:35 AM
Will this tire fit ? derekok Tire & Wheel 5 12-10-2006 12:26 PM
Will this tire fit? del105 Motorsports 8 10-05-2004 05:44 PM
Will this tire fit this rim? pio!pio! Brakes, Steering & Suspension 2 06-13-2002 07:13 PM
Will This Tire Fit? scoobynewbie Brakes, Steering & Suspension 2 12-04-2001 12:31 PM
