Old 01-15-2004, 10:23 AM   #1
kenchan
Member#: 15106
Default Optima Yellow Top: Will drain with in 2.5 weeks on WRX
I don't drive my car in the winter-time that much. My factory
battery died in 2 years. I looked around for a high
power battery and came across Optima Battery's advertising
campaign... that the Yellow Top was for cars that are not
driven all the time....only to find out that their battery is not
that great either. It drained within 2.5 weeks on my WRX;
no juice to turn over the motor. This was in a car that was
garaged in Chicago winter (approx 35F-40F inside garage)
It seems that the Subaru factory security system drains the
battery if you leave it armed. I would've expected the Yellow
Top to last at least a month without charging.
So as a warning, even if you do buy a Yellow Top thinking
that you can leave it a month without charging it, you're wrong.
Perhaps in warmer climates that may be true.
If you're planning to take a long trip leaving your car parked at
the airport for more than a week in cold weather, take a
spare battery with you and leave it in the trunk.
kenchan is offline   Reply With Quote
Old 01-16-2004, 03:57 PM   #2
atomicapples
Member Sales Rating: (10)
Member#: 12626
02 2.5 rs
you can get it under warranty.
btw : my redtop just died, so i got a yellow top.
its seems to be ok.
atomicapples is offline   Reply With Quote
Old 01-19-2004, 12:23 AM   #3
kenchan
Member#: 15106
since the yellow top is a deep cycle battery it won't die as
fast as the redtops that can't be deep cycled. so even though
it may drain all the way within 2.5 weeks in the cold, just
charge it up before use (max 10A for 8hours) and you're set.
at least we have that benefit over the normal redtops or
any ordinary acid battery.
Old 01-19-2004, 07:37 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You may want to measure the actual standy drain in your car by disconnecting one of the terminals and connecting an ammeter in series. It's possible that something in the car is causing an excessive amount of drain. Normal standy or "parasitic" drain should be around 100-200 ma or so max, if it's much more than that the battery will drain if the car sits.
Old 01-19-2004, 12:00 PM   #5
kenchan
Member#: 15106
its usually the temperature that drains it more than the car,
i think. there are many people in chicago area that their
batteries died within 3 years.
Old 01-19-2004, 12:02 PM   #6
elsanto
Member Sales Rating: (38)
Member#: 34832
1989 M3
why not just take your battery inside if your going to leave your car sit for 2.5 weeks.. it would be hard to steal the car w/o a battery IMO. would also solve this problem
elsanto is offline   Reply With Quote
Old 01-19-2004, 02:35 PM   #7
kenchan
Member#: 15106
cause you don't want to loose your ECU settings.
Old 01-21-2004, 09:52 PM   #8
sirwrx273
Member Sales Rating: (9)
Member#: 37965
2003 WRX Wagon
friend of mine had this prob with his optima red top, leaves his car in the garage here in the NW for weeks at a time...aftermarket alarm activated and everything.
He has since switched to an Optima Blue Top (deep cycle marine) and so far no problems in the last few weeks
Steve
sirwrx273 is offline   Reply With Quote
Old 01-22-2004, 01:29 PM   #9
kenchan
Member#: 15106
deep cycle is the way to go. too bad these batteries can't
hold much charge over 2 weeks. my other car using a
normal oe battery could easily go one month without a
charge.
Old 02-02-2004, 02:23 AM   #10
Redline8k
Member Sales Rating: (2)
Member#: 2968
Beat it to fit,
Paint it to match!
Im looking into a yellow top and I also live in chicago, But I drive the car every day. I want to upgrade not only for weight but for my sound system too.
What model yellow top did you get? Im also looking into relocating it to the trunk. If anyone has more info on this please let me know.
thanks
-nick
Redline8k is offline   Reply With Quote
Old 02-05-2004, 10:15 PM   #11
Mishmosh
Member Sales Rating: (1)
Member#: 45030
2004 WRX wagon
Platinum silver metallic
Consumer reports tested an Optima a few years back... turned out to have pretty poor cold weather performance (CCA).
Mishmosh is offline   Reply With Quote
Old 02-06-2004, 12:20 AM   #12
kenchan
Member#: 15106
nick- im not sure which model number, but its the one that
has 750cca. I bought mine at Sears, but Autozone has it
about $10 cheaper (i found out afterwards )
If you mount it in the factory location, you need to get a
6" + jumper as the + harness will not reach the terminal...
well, at least on mine it didn't. The ground harness is fine.
Its not so light weight, imo, but should work great for your
stereo.
michmosh (is your name suppose to be moshi moshi as in
"hello?" in Japanese?) - deepcycle batteries run lower voltage
than regular batteries.
Old 02-06-2004, 04:20 AM   #13
Uncle Scotty
Member Sales Rating: (5)
Member#: 16200
OK buy Nates beans
westcoastroasting.com
If you used a 'trickle' or 'float' charger, like all stored batteries should...you wouldn't have this problem.
Old 02-06-2004, 12:52 PM   #14
kenchan
Member#: 15106
I know. but many people including myself do not like cables
hooked up to our cars while in the garage which people could trip over or accidentally come off, etc. while not supervised.
Old 02-06-2004, 06:58 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
Put the charger under the front of the car and put a piece of duct tape over the power cord....a 'Remove before flight' flag should prevent accidental, connected departures.
Old 02-06-2004, 10:45 PM   #16
Z1 Performance
Vendor Sales Rating: (43)
Member#: 9327
why not jsut disconnect the battery while its stored for winter.......
I have an optima yellow in both the GVR4 and my other Z....both cars sit alot at various times during the year, and not a problem. Sounds like you have a drain someplace.
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Garage Sale on Lots of Parts!
- check out the blog!
Z1 Performance is offline   Reply With Quote
Old 02-07-2004, 01:34 AM   #17
kenchan
Member#: 15106
the drain is from the security system, mostly. I don't arm it
in the wintertime. The 20F temps don't help either. Don't want
to reset the ECU. Don't want cords on the floor of the garage.
I do charge it at 2amps occasionally to get it fully charged
while im working on my other car or doing something in
the garage.
Old 02-07-2004, 03:41 AM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
There are several, logical, viable solutions that have been posted and some others I'm sure....
I guess some people don't really want or need an answer, they just want to bitch.
Old 02-08-2004, 12:44 PM   #19
kenchan
Member#: 15106
My answer is to charge the battery up occassionally on 2amps
while Im working on my cars...works just fine.
Sometimes your answer does not apply to everyone and
each household...
Old 02-16-2004, 09:57 PM   #20
tdxflex
Member Sales Rating: (16)
Member#: 13634
what about using a solar charger and rewiring your cig lighter to a constant 12v instead of accessory powered 12v. Or just putting in a secondary cig lighter for the solar charger? It can stay inside the car so no cables to trip over.
tdxflex is offline   Reply With Quote
optima yellow top in a 04 wrx wkderf Electrical & Lighting 10 12-24-2003 08:29 PM
SO CAL: Optima Yellow Top car Battery brand new mturmel Private 'For Sale' Classifieds 0 11-22-2003 02:18 PM
Optima Yellow Top problem coyote73176 Electrical & Lighting 8 11-19-2003 09:13 AM
2.5 hood on WRX? vinster02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-29-2003 11:42 PM
FS: optima yellow top battery alexs001 Vancouver Impreza Club Forum -- VIC 6 07-26-2002 02:24 PM
