Old 01-18-2004, 12:15 AM   #1
markpaco
Member#: 33743
2004 Impreza WRX STi
WRB/Silver
Default WRX w/ 255/40R17 V700 What tire pressure?
I tried searching the forums but could not find any threads on suggested tire pressures for 255/40R17 Kumho Victoracer on a WRX. Does anyone have any suggested tire pressures?
markpaco is offline   Reply With Quote
Old 01-18-2004, 06:23 AM   #2
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
because almost no one runs that size
ellisnc is offline   Reply With Quote
Old 01-18-2004, 08:42 AM   #3
markpaco
Member#: 33743
WRB/Silver
What size do they typically run? 235s on the 16's?
Old 01-18-2004, 11:54 AM   #4
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
I have 255/40/17 victoracers sitting in my living room waiting for the wheels for them to arrive.
Why not run 255s? Its the biggest you can fit on a 8.5" rim without too much ballooning.
ScreaminFast is offline   Reply With Quote
Old 01-18-2004, 05:57 PM   #5
ellisnc
Member#: 4229
2003 S2000
I didn't say it couldn't be done... only person I've seen is Red Rocket that had done it but just that not many people did.
Anyway, I'd think you'd want to run a little bit lower than if you had smaller treadwidth tires just to get more rubber on the ground. But it's all related to handling.
Screamin, I hope you're only using those on the track, at autocross your gearing is going to be pretty freaking high.
Old 01-19-2004, 11:44 AM   #6
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
actually, kuhmo's website said that the diameter for the 255/40/17 victos is 24.8" which is 0.1" less than our stock diameter. So it shouldn't be any less gearing than when I was running my 225/50/16 kumho MX's...
Old 01-19-2004, 12:14 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah 255/40/17 is what you want, if it was 255/50 then the gearing would be very bad.
dwx is offline   Reply With Quote
Old 01-19-2004, 06:04 PM   #8
ellisnc
Member#: 4229
2003 S2000
On what size rim?
I think I may get you on this one
On a 7.5" rim those are going to be a little taller than on a 9" which is probably closer to the optimal size for that tire.
Old 01-19-2004, 09:53 PM   #9
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
heheh
i dunno. I did order White 17x8.5" Advan RG's
Its a little less than optimal, but i'll make due. I just want to try and max the camber without rubbing on my JICs.
Old 01-19-2004, 11:06 PM   #10
ellisnc
Member#: 4229
2003 S2000
Should clear the strut housing okay since you have 2mm less offset than me... hope you got the fender rolling machine ready
Old 01-19-2004, 11:09 PM   #11
ellisnc
Member#: 4229
2003 S2000
dude, no fair editing your posts after I already replied to them
I thought someone said 7.5" rim here and when I went back to look for it it was gone.
Old 01-20-2004, 07:43 AM   #12
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Default Re: WRX w/ 255/40R17 V700 What tire pressure?
My situation is probably completely different than yours, but what the hell...
I use 225/50/16 Victoracers on stock USDM WRX rims for track days (no autox yet). I start at 34 psi cold all around and they generally go to 42 psi hot. My car is set up to be neutral, not to rotate. Excessive rotation is not a good thing at 130.
You'd probably want to start with a little higher pressure since an on track session for me is 20-25 minutes to get that 8 psi hot.
Good luck,
Scott
sdecker is offline   Reply With Quote
Old 01-20-2004, 09:06 AM   #13
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
I ran my 265/45/16 Victo's @ 38 cold.. and they'd go to 43-45 hot. Fairly decent around there.
Do you mind if I ask where you bought your Advan RG's?
Thanks,
Fitz
www.Flat4Racing.com
Fitz is offline   Reply With Quote
Old 01-20-2004, 10:11 AM   #14
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
I don't mind at all. I got them from gruppe-s. They stock the gold ones, but I'm not a fan of white and gold, especially when I have black subaru rally graphics on the car (white car).
Hopefully the body shop that is repairing my front fender and painting/installing my body kit can alter the fenders to fit the wheels if there is any rubbing.
Lastly, rubbing is a little less of an issue because I got 600lb Eibach ERS springs going on my JIC's.
Old 01-20-2004, 10:37 AM   #15
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
+43 offset...grrr.... Wish we had the more common 114.5 bolt pattern...
Thanks,
Fitz
Old 01-20-2004, 10:42 AM   #16
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Whats wrong with the +43 ?
Old 01-20-2004, 11:58 AM   #17
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
I've flared the fenders on the car 2.5" on all corners. Currently running a Borbet Type-T in a 16x9" +30 flavor. Fits great. +43 is too high for me. To run an 8.5" rim in the same location as the current 9" +30 rim, the offset would have to be as low as +23-24mm. Hella low.
On top of that, I have plenty of room to fit a 9" rim and could squeeze a 9.5" if I had to. I'd like to run 275 series tires for One Lap this year.
Fitz
Old 01-20-2004, 11:59 AM   #18
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Oh wow, thats awesome. I wanna do one lap, but I need more HPDE's for practice first. How did you flare the fenders? You think a body shop can do that for me?
Old 01-20-2004, 04:31 PM   #19
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Anything is possible with time, money, and Charlie North.
I'll try and post some pics either tonight or tomorrow.
Fitz
what tire pressure to run stock? and what is a good aftermarket tire? jay25RS Tire & Wheel 6 06-13-2011 01:54 PM
FS: 255/40R17 Hankook Winter Tires foolio Tri-State Area Private Classifieds 10 11-20-2009 09:54 AM
new wheels and tires, what tire pressure? nickster Tire & Wheel 5 06-10-2004 12:28 AM
What tire pressure do you guys use for 17" 215 tires? V6 Brakes, Steering & Suspension 4 05-02-2002 04:00 PM
What tire pressures have you found good with the stock RE92 on Bay Area roads whomR Bay Area Impreza Club Forum -- BAIC 7 07-28-2001 07:16 PM
