Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-15-2004, 02:45 PM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default Camshaft position sensor dead
The car doesn't start and it misfires and its throwing fire threw the trottle, Timing belt in place, ignition working properly, fuel system perfect and every sensor in its place. The only thing that could be causing the problem in my opinion is the camshaft position sensor and cause of that the ignition fires out of time. Any opinion or ideas!!!
AntonioS is offline   Reply With Quote
Old 01-15-2004, 10:00 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Go buy another one. They arent that expensive.
Old 01-15-2004, 11:56 PM   #3
Unsung Boxer
Member#: 37196
the sensor is about 25 dollars. I doubt that is it. I had this same problem. I really thought it was that too, but it was the belt out of time. It is very easy to mis-time a subaru timing belt. This usually origionates because there are 2 aarows on the main pully, and often times people look at the wrong one which will put it about 90 degrees out.
I honestly question your timing belt, despite the fact you say its right. I would check it again.
YOu can line up all your marks, and pull out spark plug #3. If timed correctly, Piston 3 will be at Top Dead Center at this point
Contrary to how most engines are built, Subaru times off #3 at TDC instead of #1.
-Jake
btw, if you are condeming the Cam Position sensor because you used a scan tool, a mistimed belt will throw the SAME code.
Unsung Boxer is offline   Reply With Quote
Old 01-16-2004, 06:30 AM   #4
kaos200
Member#: 2692
on the sohc's if all the marks are pointed up aren't all the pistons half way through the cylinders?
kaos200 is online now   Reply With Quote
Camshaft Position Sensor Issue (Car won't start) Hola Service & Maintenance 2 02-06-2005 01:12 AM
Camshaft position sensor shaneswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2004 05:39 AM
Camshaft Position Sensor ehabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2003 04:06 PM
Camshaft Position Sensor zsurfrin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2002 11:00 PM
CEL code: 0340 / Camshaft position sensor BluJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-06-2001 06:07 PM
