Old 01-15-2004, 07:24 PM   #1
SMF
Member#: 52732
2004 WRB WRX Sedan
blue car fun!
Default wheel offset nirvana
Hi folks. got my wrx 3 weeks ago, and the first mod planned is wheels and tires (so it's all stock now). I've done a lot of reading about offset, scrub radius, and all that good stuff, and of course I've browsed the forums. There seems to be several opinions about offset changes. Some say don't. Some say +/- 3 mm. The offset nirvana thread appears to allow changes up to 8 mm from stock, depending on wheel width. but that seems mostly focused on fitment.
My concern is handling. I'm looking to go 17x7 or 7.5, with a 225/45 tire, and a 48 offset, and if I've done my math right, that will result in about 16mm of increase in track, and change the scrub radius to a degree also (that I couldn't calculate, and wouldn't understand if I did).
So, here's my question: if I go with et48, am I going to experience any changes in straight line stability, torque steer, bump steer, tramlining, etc.? Or should I sacrifice available variety and go 50 or higher, to minimize handling changes?
thanks in advance
steve
SMF is offline   Reply With Quote
Old 01-15-2004, 07:25 PM   #2
SMF
Member#: 52732
2004 WRB WRX Sedan
blue car fun!
Default wheel offset nirvana #2
I forgot to mention, it's a sedan.
Steve
Old 01-16-2004, 09:27 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You should be fine with a +48mm wheel (ideally on a 17x7.5). I think the biggest issue with tramlining and stability will be based on what tire you use.
Old 01-16-2004, 12:37 PM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
agreed
Old 01-16-2004, 06:32 PM   #5
SMF
Member#: 52732
2004 WRB WRX Sedan
blue car fun!
Ok, great, so et48 is fine.
and tires will be the concern for handling...
so, any suggestions there what to get, or avoid?
Old 01-17-2004, 11:21 AM   #6
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
all ROTA wheels offering for the SUBARU all have a 48mm offset.
check out the following galleries to get an idea on what will work for you:
http://www.subydude.com/gallery/
http://forums.subydude.com/viewforum.php?f=3
good luck
SD
suby_dude is offline   Reply With Quote
Old 01-17-2004, 07:37 PM   #7
SMF
Member#: 52732
2004 WRB WRX Sedan
blue car fun!
Yes, I've been to the gallery, and it was helpful in narrowing my wheel choices to SDRs, or Kazera kz-s or kz-u. they all weigh about the same, and while the kazeras are closer to stock offset (at 7 inches), the SDR is 7.5 inches which will hold a 225 tire just that much better. i like prodrive too, but they are out of my budget right now.
thanks
SMF
will lower wheel offset push wheels out giving wider stance? Cusco Tire & Wheel 8 02-03-2003 02:20 AM
what determine wheel offset? can I take vw wheels and rotors? etam Brakes, Steering & Suspension 9 05-27-2002 02:32 PM
Wheel Offset for 90-91 Legacy Peter Hadfield Legacy Forum 3 05-08-2001 05:42 PM
What Wheel Offset is right for a lowered Legacy? MY99 2.5GT Legacy Forum 15 04-14-2001 12:17 AM
wheel offset??? kastle SVX Forum Archive 5 11-27-2000 10:01 PM
