Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 01-15-2004, 11:25 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default For those using WRX exhaust
What fitment issues did you run into with the axle back portion? Does anyones piping sit way too low? Just wondering......
Brent
scoobyimprza is offline   Reply With Quote
Old 01-16-2004, 01:11 AM   #2
Kostamojen
Member#: 2272
2013 Subaru 599 :P
Galaxy Blue Sexy
Dont have mine on yet, but ill find out in a couple weeks here
Old 01-16-2004, 09:45 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Bump for the day crew.
Old 01-16-2004, 12:27 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
No problems at all. Sits perfectly. Did you get it onto the transmission exhaust hanger?
-Jon
Old 01-16-2004, 12:41 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
No. The problem I'm having is with the axle back portion. It seems that when it bends down that it sits too low to the ground and that the center hanger on the axle back doesn't go high enough for the hanger on the car.
Brent
Old 01-16-2004, 02:13 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The WRX exhaust will not perfectly mount up to the chassis. The hangers should all match up except for the one just forward of the backbox. This hanger was moved on the newer chassis and cannot be used on the older chassis unless the exhaust hanger on the chassis or the exhaust is moved.
However, it doesn't seem to be needed if all other hangers are in good condition and are used. The height should be pre-determined by the soft exhaust hangers and the rigidity and movement should be hampered by the transmission exhaust mount.
I can take a pic or two showing that it sits fine on my car. In any case, it looks factory.
-Jon
Old 01-16-2004, 02:15 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Hmm, exhaust hangers. Thanks Jon. Probably new hangers would give me a few inches.
Old 01-16-2004, 02:19 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah mine fit just like stimpy said his fit
Old 01-16-2004, 03:08 PM   #9
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
You haven't had any problems with it hitting the road on some bumps? Maybe PA roads are really that bad.
Old 01-16-2004, 04:00 PM   #10
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
no issues at all
Old 01-17-2004, 03:38 AM   #11
neverendingmods
Member#: 23796
2006 STi
white
Hey man, I know it's a different car. But on mine, when I switch axlebacks, I have to loosen the 2 spring bolts at center section and sometimes remove them entirely to properly align the piping up. I saw your exhaust hanging real low when you left and just attributed to less muffler. Hope it works for you.
neverendingmods is offline   Reply With Quote
Old 01-17-2004, 10:19 AM   #12
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
So far it's not scraping at all. I'll have pics.
Old 01-17-2004, 04:19 PM   #13
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Here's the pics.
Brent
Old 01-17-2004, 07:33 PM   #14
Aspen_2.5RS
Member#: 3310
I had that hanger (the one that doesn't mate up) relocated. I know that hanger is very close to my rear sway bar. But, I have a 3" exhaust (Borla hush) and mine doesn't appear to be quite that low.
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 01-18-2004, 01:58 PM   #15
neverendingmods
Member#: 23796
2006 STi
white
Is that metal hanger by itself resting on your underside? Looks like it in pic. May need to cut that hanger off the piping to allow exhaust to go up. You could take off a few inches off it's length then have it tacked back on if you get a rubber hanger for it.
That hanger isn't that far off from the rubber hanger. Get it to bend over towards the rubber hanger and that should bring it up quite a bit.
How does it sound?
Old 01-19-2004, 12:19 PM   #16
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
It may just be the pics, but your car looks way low. Am I crazy?
-Jon
Old 01-20-2004, 12:00 AM   #17
neverendingmods
Member#: 23796
2006 STi
white
You're not crazy. He's pretty low.
Old 01-20-2004, 12:07 AM   #18
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, my rear shocks are no good. I have JIC coilovers ready to go on though, if/when I do an AWD swap.
Oh yeah, it's Tein S-Techs on stock struts.
A couple questions for those using WRX gas tanks in their swaps… jojo Subaru Conversions 6 09-14-2006 02:21 PM
Question for those using Borla Hush? MooseWRX Factory 2.0L Turbo Powertrain 21 04-11-2004 11:35 PM
Question for those using 52mm Greddy and OEM pod the2rz Interior & Exterior Modification 4 03-25-2004 06:56 PM
Question for those using Falken Azenis Tires MooseWRX New England Impreza Club Forum -- NESIC 2 03-21-2003 03:58 PM
Question for those using the Dawes boost controller skoobahead Factory 2.0L Turbo Powertrain 10 05-17-2002 04:25 PM
