Old 01-16-2004, 03:05 PM   #1
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
Default 235 45r17 bridgestone blizzak LM-22 on a WRX wagon
Hi. I might be able to get a deal on these, and I'm wondering if they will fit on my wagon: 235 45r17 bridgestone blizzak LM-22. Thanks.
McBain_TP is offline   Reply With Quote
Old 01-16-2004, 03:11 PM   #2
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
225/45-17 seems to be a tight fit on a wagon at best. With the additional width (and diameter) of a 235/45-17, I would guess that your chances of fitting it without rubbing are slim.
TheWRX is offline   Reply With Quote
Old 01-16-2004, 03:14 PM   #3
David Clark
Member#: 39168
2002 WRX Wagon
my 225/45-17 LM-22's rubbed until I cut the lip out of my fender wells...
David Clark is offline   Reply With Quote
Old 01-16-2004, 04:08 PM   #4
McBain_TP
Member#: 43986
2002 WRX wagon RIP
Aww nuts. Ok thanks guys.
Old 01-16-2004, 04:12 PM   #5
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Depends on the offset of the wheel also. i had the same problem as above witha wheel witha 40 mm offset. hope that helps. other than that the clearance seemed fine
scoobdude is offline   Reply With Quote
Old 01-17-2004, 11:24 AM   #6
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
if you run a 7.5" wheel w/ a 48mm offset... you'll be rubbing for sure....
if you are going to get a good deal on those tires... it might be an option for you to do some fender modification but it might still be too big.
good luck.
SD
suby_dude is offline   Reply With Quote
NEW! 215/45R-18 Bridgestone Blizzak LM-22 XL Open to trades on anything! Rat^3 Wheels/Tires 4 02-12-2010 06:14 AM
FS: Four Bridgestone Blizzak LM-22 tires 235/45r17 Padge MAIC Private Classifieds 28 06-13-2009 02:44 PM
FS: Four Bridgestone Blizzak LM-22 tires 235/45r17 Padge Tri-State Area Private Classifieds 11 01-27-2009 05:46 PM
For sale - cheap: 4-Bridgestone Blizzak LM-22 225/45/R17's Tires oriond Private 'For Sale' Classifieds 0 08-19-2005 09:02 AM
FS: 205/55/16 Bridgestone Blizzak LM-22 nizz Tri-State Area Forum 8 09-15-2004 04:10 PM
