Old 01-16-2004, 06:02 PM   #1
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Default EJ25 Intake Manifold fit on EJ20?
Will the EJ25(from a 2.5RS) intake manifold bolt onto the EJ20(from a wrx) longblock?
FatCatTurbo is offline   Reply With Quote
Old 01-19-2004, 09:50 AM   #2
Imprezd
Member#: 3357
I doubt it.. but i do have one for sale $100. With TGV Housing, and Fuel Rails.
Imprezd~
Imprezd is offline   Reply With Quote
Old 01-19-2004, 04:29 PM   #3
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
Default Re: EJ25 Intake Manifold fit on EJ20?
Depends on which EJ25 and which EJ20.
Old 01-19-2004, 09:09 PM   #4
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
USDM 1998 2.5 RS and a USDM 2002 WRX.
Old 01-19-2004, 09:29 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Old 01-19-2004, 11:25 PM   #6
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Actually I dont know, its a phase I vs. a phase II...
Old 01-24-2004, 08:29 AM   #7
Section 8
Member#: 821
98 intake manifold will not fit the USDM WRX heads. THe bolt pattern is completely different. THe USDM WRX and 2000, 2001 and most 1999's (assuming that there are indeed MY99 with DOHC and phase 2 blocks, people have said that they have one, I have never seen one).
The DOHC 98 2.5 has a bolt pattern like this:
0
0
0
0
WRX and SOHC 2.5's have a bolt pattern like this:
0
-->0
-->0
0
such as the pictures in the posted thread.
It is one of the differences between phase 1 and 2 engines. You could use the DOHC 2.5 manifold for a GC8 WRX long block. I have had DOHC, SOHC heads, and Phase 1, 2 and WRX intake manifolds in my possesion.
Not all Phase 1 intakes are the same however, if youstart to go older the intakes are significently smaller and will not match the ports inthe head even if the bolt patterns match.
Greg
Section 8 is offline   Reply With Quote
JDM EJ20 with a STI EJ25 intake manifold?? + ECU questions vincyboy Newbies & FAQs 5 02-10-2008 12:39 PM
manifold swap? will a old legacy manifold fit on ej20 heads? devildevil Subaru Conversions 1 03-11-2007 01:14 AM
this might be dumb: but would an STi intake manifold fit on an NA 2.5RS? Impreza2003 Normally Aspirated Powertrain 15 06-22-2005 11:58 AM
EJ20/EJ25 Intake manifold swap Really_Soaked Normally Aspirated with bolt-on Forced Induction Powertrain 3 07-25-2002 10:28 AM
Will the WRX intake manifold fit on the ej25 heads? Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 25 01-20-2002 12:33 AM
Message Board Statistics All times are GMT -4. The time now is 03:57 PM.
