Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 01-16-2004, 06:23 PM   #1
Scbullit
Member#: 52814
1997 Outback Sport
Forest Green
Default Stuck Key in Ignition
I have a 5 spd 1997 Outback Sport. I started up my car today and when I went to go pull out my key from the car, it wouldn't push in to come out. I looked at it and it looks like the key wasn't put all the way in. But the car still starts and everything but I can't get the key out. How do I remove the key?
Scbullit is offline   Reply With Quote
Old 01-16-2004, 06:46 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....don't force it!!!!!
There was a thread, here recently, dealing with that specific issue.
The answer was posted by a realhonesttogod(so he said) locksmith.
Something about a small pin type release on the bottom of the cylinder....have to remove the plastic cover on the bottom of the collum.....Do a search....I wouldn't care to give you false info...
Found it....http://forums.nasioc.com/forums/show...ight=stuck+key
Old 01-16-2004, 07:42 PM   #3
Scbullit
Member#: 52814
1997 Outback Sport
Forest Green
I removed the plastic cover surrounding the sterring column but I am unable to locate this release button/screw.
Old 01-16-2004, 08:27 PM   #4
avk
Member#: 17252
'06 WX8
59E
It should be in the owner's manual. You don't have to remove the whole cover, only the round plug with a Phillips drive,
and push with something. The locksmith's post probably was in some other thread.
avk is offline   Reply With Quote
Old 01-16-2004, 10:43 PM   #5
Scbullit
Member#: 52814
1997 Outback Sport
Forest Green
Yes that release lever is in the manual. But it is only for automatic vechicles and not for manual cars. How do i remove my key with out going to the dealership.
Old 01-17-2004, 01:14 AM   #6
avk
Member#: 17252
'06 WX8
59E
Just realized that lever is a part of AT shift interlock, it manually releases a solenoid that MT doesn't have. Always thought it was for mechanically releasing the key from the cylinder. What you probably need to do is to remove the lock cylinder (not the complete lock). The manual shows the cylinder come out to the outside, but doesn't tell how. It shouldn't be very hard because replacement cylinders are sold in many places.
Old 07-05-2004, 06:10 PM   #7
Rusty1
Member#: 65672
I'm also having this problem. I have a 1997 impreza outback MT, and the key won't come out. Tried turning the wheel back and forth. Since it's not an AT, it doesn't have the release switch like the manual says.
Trying to get the key out for so long, I forget if I need to have the clutch in.
Any ideas? Has anyone fixed this problem.
Thanks,
Rusty
Rusty1 is offline   Reply With Quote
Old 07-09-2009, 10:02 AM   #8
mikerihl
Member#: 216622
Default key stuck
I have a 97 automatic impreza outback sport and the key is stuck also. I read the manual and did what it said but cant seem to find any kind of switch after I took out the plug. Any suggestions? The steering isnt locked either now when I shut it off.
mikerihl is offline   Reply With Quote
Old 06-27-2011, 09:12 AM   #9
mark_b10
Member#: 286275
1993 Impreza LS
I have a '93 Impreza, automatic. I had the same issue, but there is a little switch under the actual shifter handle that releases the key. If you remove the console around your shifter, there is a tiny black box at the base of the shifter on the right side with a small button on the bottom side. There should be a tiny strip of metal that clicks the button when you go to turn the car off, but you can manually click that button when you have the key as far off as it can go, and it will release the key to finish turning and be removed.
mark_b10 is offline   Reply With Quote
4EAT to MT swap - Key stuck in ignition? silentt Transmission (AT/MT) & Driveline 3 08-21-2008 05:42 PM
key stuck in ignition after auto to manual wrx swap spiralsmurf Subaru Conversions 7 11-23-2005 04:58 PM
Key stuck in ignition? spotlfe Car Audio, Video & Security 11 08-10-2005 10:47 PM
Weird Key stuck in ingition story Ordinary Vanity Off-Topic 14 12-30-2004 12:07 PM
Key stuck in ignition Clausen Service & Maintenance 3 01-01-2004 12:04 PM
