Old 01-17-2004, 05:55 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Question Here's the FINAL WIRING question on EJ20G
ok....i'll lay out EXACTLY all the wiring i've done, maytbe then someone can tell me why i see only 1.6 volts at the ECU for all 4 fuel injectors.
All these sensors are wired into their repective ECU pinouts. Grounds from all the sensors are grounded into the pressure sensor ground wire via the wiring schematics.
all pressure sensors, o2 sensor, MAF, TPS, IAC, Ignitor Pack, Cam angle, Crank angle, CLT, knoick sensor, all 4 fuel injectors
the injectors are being grounded by the injector ground wire running to the ecu.
when the ignition is on and the ignition wire to the ECU is at 12v, the ignitor pack is reading 12 v on all wires, the MAP is getting power, all sensors that get power at that time are powered. the 4 injectors are at 1.6 volts.
the ECU is grounded using all ground wires to a battery ground, not a chassis ground. i tried the chassis, but it wouldn't power up.
THe codes being flashed are 14 - 17, the 4 fuel injkector codes.
help? what the hell is missing from this? Oh yah, the injectors are supposed to be getting 12 v power, not 1.6.
thanks,
eric
smacksube is offline   Reply With Quote
Old 01-17-2004, 07:46 PM   #2
Structure828
Member#: 50488
1999 GC8 ej20g!
If anyone has any information or can help please do so. Your posts are really needed. I am willing to write the person that can give the answer that solves the problem a check for an un-disclosed amount. If you have any questions you can email me at [email protected]
I really appriciate the effort and input from you guys and I hope we can get to the bottom of this. We are 1 problem away from completion...
Structure828 is offline   Reply With Quote
Old 01-17-2004, 08:56 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes
after playing with a simmilar (kida) proublem on a frineds car last week the +12v to the injectors does not have to be switched it can be constant .. try another 12V source.. at least to get the car initialy fired..
is the 1.6V the reading befor or after the injector?
Old 01-17-2004, 09:56 PM   #4
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Did you check the power voltage at the air control vavle and purge valve. They should be on the same circuit as the 12volt supply for the injectors.
Ver.III is offline   Reply With Quote
Old 01-18-2004, 11:19 AM   #5
smacksube
Member#: 4067
01 2.5 rs
Originally posted by Jaxx
yes
so as long as the injectors are grounded through the EVU injector grounds, i can use any external 12v constant power source? sweeet, i'll post up soon whether this works or not..thanks!
Old 01-18-2004, 11:20 AM   #6
smacksube
Member#: 4067
01 2.5 rs
The IAC was another code i was throwing, after volt checking the wires i wiried it up to 12v and the code went away, maybe this is where it's all going wrong....thanks alot for the input guys!
Old 01-18-2004, 07:16 PM   #7
Structure828
Member#: 50488
1999 GC8 ej20g!
TY guys, Smack is gonna try to get it workin off of what you guys said and we will take it from there. I really appriciate the input, if anyone else has any info, let us know.
THANKS GUYS......
Old 01-19-2004, 01:37 PM   #8
Structure828
Member#: 50488
1999 GC8 ej20g!
Old 01-19-2004, 07:13 PM   #9
smacksube
Member#: 4067
01 2.5 rs
ok...so now i'm a little confused. The ecu has 2 wires going out for injector grounds. later in the harness the come together and lead out as 1 big wire. so this means the injectors are constantly grounded and open when any of the wires from the ecu see 12v. right so far? so if all grounds are correct then why would i only get 1.6v at the ecu and not 12v? is my thinking correct? or is this computer possibly messed up?
if i attach a constant 12v to the injectors then all of them will be opening at the same time, eh? the car def. won't be able to drive like this. It may start momentarily but there's gotta be a better approach. The last thing needed is a catastrophic failure due to detonation or pre-ignition or something lame like that.
Old 01-19-2004, 10:01 PM   #10
Structure828
Member#: 50488
1999 GC8 ej20g!
Old 01-19-2004, 10:16 PM   #11
Ver.III
Member#: 1185
I flap my gums
Injector should have 12volts which if you look at the injector wires , one wire will be common color for all four (ie. yellow/blue) This will be the 12 volt supply. The second wire on each injector will be the signal wire which each wire on each injector has a different color. These wires go to the ecu, normally bunched together on one connector. The ecu has injector drivers internally , which will ground out the signal wire causing the injector to pulse(open) If you are measuring the signal wire with the connector still plugged into the ecu , you should still see the 12volts when the ignition is on. If you disable the ignition and crank the car , the voltage should fluctuate. If you have a high impedience test light , it will be easier to see.
Old 01-19-2004, 11:32 PM   #12
smacksube
Member#: 4067
01 2.5 rs
ok i'll try that. i was hooking up the injectors to the drivers and then grounding them out through the ecu pinouts labeled 'injector grounds'. i'll try swapping the 'grounds with the constant 12v and hooking up the other wires to the ecu.
Old 01-20-2004, 02:09 AM   #13
Ver.III
Member#: 1185
I flap my gums
Originally posted by smacksube
ok i was hooking up the injectors to the drivers and then grounding them out through the ecu pinouts labeled 'injector grounds'.
NO , the pinout that says injector grounds DOES NOT mean that you ground the injectors to that wire. The wires that come from the ecu that says injector grounds GOES to the ground on the car or negative terminal of the battery. On your ecu pinout sheet, the pins that say injector 1 , injector 2 , injector 3 , injector 4 . means the other wire that comes off each injector(not the 12volt supply) goes to those pins accordingly.
Old 01-20-2004, 04:56 AM   #14
smacksube
Member#: 4067
01 2.5 rs
oooooooh....so that's the big freaking misunderstanding. so many people were telling me to ground to the ecu, not the engine and that the 12v power comes from the ecu not a constant. now i think this project can finally be freaking completed!!!! thankyou much
Old 01-20-2004, 11:49 AM   #15
Structure828
Member#: 50488
1999 GC8 ej20g!
YAY! Hopefully it works. If not we will be right back here on the boards
Old 01-20-2004, 12:44 PM   #16
Ver.III
Member#: 1185
I flap my gums
12volts does not really come directly from the ecu . Power for everthing should come from the main relay , the brown one with a brown connector that is usually paired with the fuel pump relay which is the round silver with the green connector. There should be 2 wires of the main relay which are power when ignition is turned on. Everything means injector power , ecu power , air control valve , purge valve , boost control valve , pressure sources valve....etc.
Old 01-20-2004, 04:12 PM   #17
Structure828
Member#: 50488
1999 GC8 ej20g!
LOL, I hope Eric gets it right and my car doesnt blow up. TY again guys for the help, I got a good feeling this time.
Old 01-20-2004, 04:29 PM   #18
smacksube
Member#: 4067
01 2.5 rs
ok...last question. what code is being flashed with 5 short flashes? i couldn't find it on any manuals i've d/l'd. they all start at code 11.
Old 01-20-2004, 04:44 PM   #19
smacksube
Member#: 4067
01 2.5 rs
5 short blinks eh
Old 01-20-2004, 07:10 PM   #20
Structure828
Member#: 50488
1999 GC8 ej20g!
you know Ver3? You seem to know everything bout this stuff
Anyone?
Old 01-20-2004, 07:11 PM   #21
smacksube
Member#: 4067
01 2.5 rs
hahaha...it matters not now...the beast has roared to life!
Old 01-20-2004, 08:24 PM   #22
Structure828
Member#: 50488
1999 GC8 ej20g!
w00t
Old 01-21-2004, 09:01 PM   #23
Structure828
Member#: 50488
1999 GC8 ej20g!
My car's out of the shop!! Here's the final list of stuff for sale Cashis Private 'For Sale' Classifieds 68 02-06-2006 03:50 PM
where do i wire up the warning wire to on a 60mm greddy gauge? rhd Electrical & Lighting 4 02-26-2005 05:15 AM
injector question on EJ20G 99WRXEJ20 Subaru Conversions 1 12-11-2003 03:24 AM
Anyone know the final drive ratio on the JDM STI type ra 2001 ??? alfriedesq Transmission (AT/MT) & Driveline 4 07-17-2002 03:50 PM
Ok guys here's the final design for the '95-'99 Legacy Body kits GTBGUY Legacy Forum 6 02-25-2001 12:49 AM
