Old 01-18-2004, 01:21 PM   #1
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
Default Rota Attacks
What's the word on the street (no pun) regarding Rota Attack wheels? I am planning on a set of 17's. Would a like-new set of STi potenza RE 70's fit and be reasonable for dry/wet performance and daily driving? Are other than OEM lugnuts recommended? Are the black inserts functional?
Thanks,
MARK
Subahaulic is offline   Reply With Quote
Old 01-18-2004, 01:33 PM   #2
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
RE070's will fit, but I hear they're dodgy in the rain.
Aftermarket lugnuts are required for Rotas
The inserts are for show only
WagonMonster is offline   Reply With Quote
Old 01-18-2004, 02:35 PM   #3
Subahaulic
Member#: 51163
Wagonmonster--many thanks.
Do the correct lugnuts come w/ each wheel set? Where is the recommended source, if not?
Mark
Old 01-18-2004, 02:56 PM   #4
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
lugnuts do not come with the wheels, you need to find tuner lugs. mcGard splinedrives are great but will also run you about 70-80 bucks. i got kyokugens for $40.
I just got myself a set of attacks not long ago. I put on falken grB's. They seem great so far, excellent grip wet and dry, and are pretty quiet too.
By the way the attacks weigh 17 lbs, not 15 or 16 which many places advertise.
eyeballs is offline   Reply With Quote
Old 01-18-2004, 02:57 PM   #5
WagonMonster
Member#: 3781
Any vendor who sells Rotas should either provide you with the proper lugnuts or offer to sell you them.
I believe suby_dude reccommends McGard Lugnuts
Old 01-18-2004, 06:50 PM   #6
static_rst
Member#: 50155
what? dude, i was goign to order them because they were the same as stock or a little lighter! What gives? Did you weigh them? (rotas)
static_rst is offline   Reply With Quote
Old 01-18-2004, 10:50 PM   #7
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
yup i weighed them on my bathroom scale and I had edge racing weigh them on the scale they use which looked like a really good one. Their scale read 17.0 lbs which is about the same as i got on 2 different bathroom scales.
Old 01-18-2004, 11:15 PM   #8
ripvw
Member#: 27790
Rota themselves has always stated that the Attacks weigh 16.5 lbs. which is the same as the stock wheel. But consider what you're getting: an inch larger wheel and an inch wider wheel for the same weight. That's excellent for the price which is why I'm buying them as well.
To get appreciably lighter wheels you need to spend about $400 more a set for the Enkei RPF-1's - which weigh about 1.5 lbs. less per wheel.
But Keith Casey seemed to do ok in autocross last year running the 16.5 lb. Attacks with the 26 lb. Falken Azenis Sports. Maybe there's more to life and racing than unsprung weight and rotating mass.
I would also recommend the Falken GRB FK451's. A lot of people want to compare them to Yokohama ES-100's because of the price but in this test from Germany's Auto Motor und Sport magazine the Falkens held their own against Toyo TS1's, Goodyear F1 GS-D3's and Dunlop SP 9000's - i.e. some of the best wet-biased max performance tires available.
http://www.falken-europe.de/common/i...fs/sa_test.pdf
ripvw is offline   Reply With Quote
Old 01-18-2004, 11:37 PM   #9
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Rota Attack 17" weights between 16-17 lbs... depending on color... the darker the finish the heavier the wheel.
but w/ a 1 lbs difference between the color i doubt you'll be able to tell the difference once its on your ride...
as far as year round tire... the Falker Ziek 512s got #1 rating for year round performing tires.
if you want to see attacks on on cars you can check:
http://www.subydude.com/gallery/
and
http://forums.subydude.com/viewforum.php?f=3
good luck!
Sd
suby_dude is offline   Reply With Quote
Old 01-19-2004, 05:19 PM   #10
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
well my royal steel grey's were 17 lbs. I imagine if you got silver they would be lighter.
Old 01-19-2004, 05:31 PM   #11
Flat420
Member#: 35455
07 LGT Spec.B Stg2
I've got two sets of 17" steel grey attacks (one set with f1 GS-3D's, one with RA-1's) and have been very happy with them.
As for lugs, Suby Dude has Dulamin lugs, which will save you that half pound you're worried about over stock or chrome lugs!
Flat420 is offline   Reply With Quote
Old 01-19-2004, 06:43 PM   #12
Subahaulic
Member#: 51163
What's the word on Zenki lugs? Hope they'll work on the Attacks.
FS SCIC: Silver Rota Attacks / Attack Rally1 Private 'For Sale' Classifieds 19 06-17-2004 07:54 PM
Do Rota Attack and Rota Tarmac wheels clear the 6-pot Wilwoods? trhoppe Brakes, Steering & Suspension 0 04-28-2004 10:04 AM
WTT: 17" Gunmetal Rota Tarmac 1 for Rota Attack (silver or bronze) soundwave Bay Area Impreza Club Forum -- BAIC 0 03-22-2004 04:51 PM
Rota attacks or Rota sub-zero's? zavala Tire & Wheel 1 03-11-2004 03:11 PM
anyone has the Rota Attack on their WRX? rayw1128 Brakes, Steering & Suspension 3 05-28-2002 01:32 PM
